Creating AIF Channel
Hi ,
Am currently using Dynamics AX 2009 .While am creating a new Outbound channel in Channel form it throws the following error “The path C:\AIFOutbound\ does not exist or is not accessible from an AOS server. Always use a UNC path.”. Please anyone help me how to fight this problem? Thanks in Advance…
check the rights on the folder and drive. u must hav a admin rights.
Hi Arun,
I gave all permission to this drive or folder .but still i got a same error…
Does the path exist on AOS and does the AOS service have sufficient permissions? Nevertheless note that I’ve never tried to ignore what AX says and I always used an UNC path (\…). I recommend the same to you.
