I have created a dataport for sales header and i need to validate the customer no when importing. this is fine.
As am validating the customer no., if the customer does not have Customer posting group then system is throwing an error message and interupting the import process.
I want to capture the error message and store in a table and skip the record and process the next in the excel file.
Is it possible to capture the error and store in a table when using dataport?
Thanks Dave. i can understand as far as Customer posting group. But
validation for Customer no. have lots of functionality that will error if any data missing. is there a way to update the error in a table, if there is any error captured when validating.
Unfortunately not, there is no error trap trigger to let you handle the error and proceed. What I would normally do is to dataport into a custom table and write a routine to update/validate from the custom table. This allows you to flag records causing an error and correct them later.
Would you please explain me more on this. Here what you say as Custom table is “Sales Header” as per my requirement or it is any temporary table that i need to create and update before importing into Sales header?
I normally create a new table to import the data into (in a custom range) and then do an update into the Sales Header table. This allows you to review/fix the data in the custom table and does not interfere with the standard operations.
