Validation while importing Records
Hi All, I am making a dataport and i was wondering Whether is it possible to validate the record while inserting it from a dataport. To be more precise…suppose i am inserting records into customer Table and its one of the field has a table relation set. for ex. “Territory Code” Field… Now when i enter some data directly from the table or form,it throws error. But when i import data from Dataports into customer table …It takes value without throwing error.[?][?] Thanks
CallFieldValidate is the property you are looking for. You can find it, for each field, in the Field Designer.
Well my problem is something different…For a TableRelation property we dont write any code on the Onvalidate trigger…isint!!..so i’ll validate the Records which i am inserting through Dataports. For ex. Territory Code" field in the customer table.
quote:
You could write some code on OnAfterImportRecord trigger on the dataport. There you could make any validation you want and processing of the data imported. Good luck!
Thanks Nelson. I got your point.
Have you actually tried using CallFieldValidate?
Oh OK, we cross-posted each other [:)]
