I have a dataport that imports data into a table. I want to do validation of the columns that gets inserted and stop insertion of the rows that fail validation and process the rest.
Can someone tell me how to achieve this.
-Sudhakar
-Sudhakar
Are you inserting into table fields directly or into variables?
If you are using table fields then there is a property called CallFieldValidate, which is by default No. set it to Yes, it will run the onvalidate trigger of field…
When the validation fails how to ignore inserting that row and let the dataport process the rest of the rows.
