C/ODBC -> Access: Double Field Definition?
Hi all, I want to import the table 18 Customer from Navision 3.70B native into Access2003. But I get the Failure “You can’t define a field twice!” (“Feld kann nur einmal definiert werden!”). What does this mean? It is impossible to define double fields in Navision. And I can import other tables without problems into access. What can I do to get my debtors imported? Thanks in advance Ulf
Ulf, Have you double checked your table definitions in Access?
In Access there is still no Table “Customer”, which I could check. Ulf
Hi, Have just tested with version AU 3.70A and MS 2003 SP2 and it worked fine. Can you link to the table or does that cause the same error? Access converts any field ending with . to _ such as No. to No_ so if there was also a field No_ in Navision the would be considered duplicate. Could be that in your version of Navision you have two fields such as the above example.
Just for info: The field names were not twice. But there were two double german captions. They made the trouble. Regards Ulf
