I am trying to review a demo of Jet Reports and needed to install the appropriate C/FRONT version for the database I wish to connect to. I have multiple Navision clients installed on my workstation. The installation instructions for C/FRONT state the following: If multiple Navision Financials systems are installed, the function SetNavisionPath in the cfront.dll library must be called specifying the path to the directory where Navision Financials is installed. Can someone please explain where I would set this function? Thanks, James
It means that you have to give the path for the Navision executables. For example, if you have Navision 2.0, Navision 2.5 and Attain 3.1o installed on the computer and want to use CFRONT with Navision 2.5, then you must specify the path fro Navision 2.50
Thanks for the reply. I have resolved the issue by installing the SKD toolkit and then pointing Jet Reports to the appropriate database and license.
