I am working on a BigText thing at the moment. I found everything i need except for the possibility to delete a PART of a text. Is it really true that there is nothing alike? I can freely add and find Text but i cannot remove? Hmm … i don’t get the sense in that… [?]
well basically i am trying to replace a string in a bigtext. but the problem lies deep within navision 4.00. when you send a report to shortcuts it saves its tableview including “ShowREquestForm = Yes”. But when i open a database using german language it gives me an error that “Yes” is not an option … but “Ja” and “Nein” would be. and therefore id like to load the contents of the UserMenuLevel into a BigText and Replace every “Yes” with “1”. Although i doubt that this is a good solution …
well actually i cant since the link is a BLOB inside the UserMenuLevel and contains binary data. i could write myself a tokenizer and read byte per byte, but that is way too complicated and i am way too busy for that at the moment =) maybe you all will see a resolution post here the next months …
