Using BLOB and BigText
Hi, I am trying to use a single field in Navision to store the text for the body of an email when using reporting services (SQL). Using Client 4.02.23099.
What I have tried so far: Use BigText (addtext) to create the lines. Then outstream it to the BLOB field.
Now I would like to extract the text out of the BLOB in SQL so to get the body text. I have tried the CONVERT funciton but SQL says that “Image” blob cannot be converted. I checked the setting of the blob in Navision and change to Memo sub-type and also set compression = no. Still no luck [:(]
Anyone tried anything similar?
Thanks,Nic
Not sure but I think if you search mibuso for STREAM & BLOB there are some posts.
I’m not familiar with this, Kamil postsed a download perhaps this can point you in the right direction
http://www.mibuso.com/dlinfo.asp?FileID=343
Thanks Savatage, I am fine with Navision’s handling of the Blob.
E.g.
BigText.ADDTEXT(‘Line 1’);
BigText.ADDTEXT(‘Line 2’);
BigText.ADDTEXT(‘Line 3’);
Rec.BLOB.CREATEOUTSTREAM(OutStream);
BigText.WRITE(OutStream);
It’s just that I would like to get the Text out of the from SQL’s point of view.
Nic
Thought I would update and close my posting because I came up with a solution:
It is possible to get the text out of a BLOB as I was trying to do.
The SQL code to convert Navision BLOB into something SQL can use as text is:
CONVERT( varchar(2000), CONVERT (binary, BLOB)) AS BLOB
Then you can use the field in Reporting services etc.
Hey Nic, very much appreciated tht you took the time to post this, thanks [:D]
