I have deployed the same application on two server. There are 6 batch in my application. The problem is with only one batch ,its running on one server but on the other. There are no errors and nothing in logs. I even check the time for which scheduler should trigger to run the batch but its same on both the server. Can you help me with what have gone wrong???
Best regards,
Babita
