I have same code on two servers.
I have job for adding batch job to the queue
static void Job_ScheduleBatch2(Args _args)
BatchHeader batHeader;
BatchInfo batInfo;
RunBaseBatch rbbTask;
str sParmCaption = “My Demonstration (b351) 2014-22-09T04:09”;
SysRecurrenceData sysRecurrenceData = SysRecurrence::defaultRecurrence();
sysRecurrenceData = SysRecurrence::setRecurrenceStartDateTime(sysRecurrenceData, DateTimeUtil::utcNow());
sysRecurrenceData = SysRecurrence::setRecurrenceUnit(sysRecurrenceData, SysRecurrenceUnit::Minute,1);
rbbTask = new Batch4DemoClass();
batInfo = rbbTask .batchInfo();
batInfo .parmCaption(sParmCaption);
batInfo .parmGroupId(""); // The “Empty batch group”.
batHeader = BatchHeader ::construct();
batHeader .addTask(rbbTask);
batHeader.parmRecurrenceData(sysRecurrenceData);
//batHeader.parmAlerts(NoYes::Yes,NoYes::Yes,NoYes::Yes,NoYes::Yes,NoYes::Yes);
batHeader.addUserAlerts(curUserId(),NoYes::No,NoYes::No,NoYes::No,NoYes::Yes,NoYes::No);
batHeader .save();
info(strFmt("’%1’ batch has been scheduled.", sParmCaption));
and I have a batch job
class Batch4DemoClass extends RunBaseBatch
int methodVariable1;
int metodVariable2;
#define.CurrentVersion(1)
#localmacro.CurrentList
methodVariable1,
metodVariable2
endmacro
public container pack()
return [#CurrentVersion,#CurrentList];
public void run()
// The purpose of your job.
info(strFmt(“epeating batch job Hello from Batch4DemoClass .run at %1”
,DateTimeUtil ::toStr(
DateTimeUtil ::utcNow())
public boolean unpack(container _packedClass)
Version version = RunBase::getVersion(_packedClass);
switch (version)
case #CurrentVersion:
[version,#CurrentList] = _packedClass;
break;
default:
return false;
return true;
On one server it do runs and in batch history I can see it is saving messages to the batch log and on the other server it does nothing. One server is R2 (running) and R3 (not running).
Both codes are translated to CIL. Both servers are Batch server. I can see the batch jobs in USMF/System administration/Area page inquries. Only difference I can find is that jobs on R2 has filled AOS instance name in genereal and in R3 it is empty. In R2 I can see that info messages in log and batch history but there is nothing in R3.
Any idea how to make batch jobs running?
AX 2012 R2 and R3
