Dear Friends,
How can we configure batch job in dynamics ax 2009.
my problem is that i have integrated dynamics ax with some other s/w using excel file, now i have to read daily this excel file from a particular location to my system using executable class, so i want a batch job which execute my class daily on a fix time…!!
Please help.
Rgds
BK
You can run this job to add batch processing for your class:
// Read excel from batch processing - By Vishal
static void BatchJobSchedule_ExcelImport(Args _args)
BatchHeader batHeader;
BatchInfo batInfo;
RunBaseBatch rbbTask;
str sParmCaption = “ExcelReading”;
rbbTask = new ExcelImport(); // Your class name which contains the logic to import from excel.
batInfo = rbbTask .batchInfo();
batInfo .parmCaption(sParmCaption);
batInfo .parmGroupId(""); // The “Empty batch group”.
batHeader = BatchHeader ::construct();
batHeader .addTask(rbbTask);
batHeader .save();
info(strFmt("’%1’ batch has been scheduled.", sParmCaption));
Thanks vishalji for prompt resposnse,
everything is ok for batch processing but issue is that i have to read an excel file using server side batch job
which is not possible as i have searched on the web, microsoft not provide a way to use sysexcel class at server side.
if this is right than i m thinking to use dotnet methods in Ax to read excel file so that my batch can run on server side without consuming a client license …!!
pls help or suggest
Rgds
BK
