I need an urgent help. Can you please tell me installation steps.
I ve got task to install Axapta with:1. SQL server 2. Axapta 3.0 SP6
I ve installed SQL server. But how I understand I need also to additionally download Microsoft Axapta, because SP6 is just an upgrde. Am I right or not?
Yes - you have to download Dynamics Ax 3.0 and SP6 separately.
Don’t open Ax until you finish installing SP6. In other words, after you install SP6, only then open Ax client and go through check lists (installation and upgrade)
Yes. You have to install 3.0 software first. And then SP6.
You can download software ONLY from CustomerSource or PartnerSource (possibly from MSDN as well. You need to check!)
Also you would need Ax 3.0 license file to complete the installation. Once you purchase the license file, you will receive this from your partner. If you work for partner, you can download this from PartnerSource.
