Axapta Installation--SQLSERVER 7.0
hi, there is a case — a client has SQL Server 7.0 Installed on his M/c. He wants the 2-tier installation of Axapta on the M/c The Application also resides on the Same M/c & the Client too. Also Database is also on the Same M/c. How to go with such type of Installations. Thank you regards Vaibhav
If msde is installed remove msde if u r using SQL as the DataBase server. Yes u can install the application and client on the same m/c with the Sql database. first install the Sql then the axapta application select a folder than install the client. Then configure the ODBC connection then configure the same in the axapta configuration utility by selecting the database configured inthe ODBC, then start Axapta, it will ask for license provide the path for the license and then compile it may take an hour or more than synchronize it that’;s all.
Thank you Mohan very much.
