I encounter an error message when updating release batch order. The error message prompts:
“Production order DYS-000007 could not be scheduled. Not enough capacity could be found”
Does anybody know where/ what are the missing setups?
Lee
Your production order has a route, the routing goes through work centres. The work centres and scheduling are probably finite capcity. The work centres have a calendar moving forward with working times. You can change all or some of these, simplest thing is to look at the capacity required and make sure there is time in the calendar to achieve it.
