The issue was that the fields in the dataset were displaying a 1 at the end eg. Itemid was represented as Item1 so I recreted the dataset by deleting the original but now the drillthrough methods are gone.
I deleted all the changed but even then the drill through methods are not seen in the original Report .
For this, please close your solution in visual studio and then re-build it. this problem occurs due to synchronization problem. Just close the the report solution and the the project in Solution explorer, you will get issue resolved.
when the fields shows like “filedname1” it’s because the filed’s extend data type is an Enum, so the field show in the datasit at visual studio as two fileds 1-Name 2-Label , so if you want to use it, use the Name field in the Datasit, and make sure that after you add an item to the table to refresh the datasit in the visual studio before you added to the design,
