ax 2012 , Error while setting server report parameters. Error message: The item ‘/DynamicsAX/StaticReports/en-US/queryBasedReport.Design’ cannot be found. (rsItemNotFound).
Can any one suggesten me on this problem…
Hi Dhanasekar,
ur ssrs report is not deployed.
Hi Arun, I have deployed the report but i am a new error
i.e For more information about this error navigate to the report server on the local server machine, or enable remote errors"
and I have set the EnableRemoteError True, but still getting same error. how can i resolve it…
I m getting this error in Axapta 2012 R3 and using 2008 sql server.
Please help me out.
Hope for early reply.
thanks in advace.
Sachin chauhan.
Can you check the Event Viewer for any errors logged in?
Hi Anand, the detail is here…what is this. i m not getting this.
| - | System |
- Provider
[ Name] Microsoft.Dynamics.AX.Frameworks.Controls
- EventID 1000
[ Qualifiers] 0
Level 2
Task 0
Keywords 0x80000000000000
- TimeCreated
[ SystemTime] 2014-08-27T06:35:58.000000000Z
EventRecordID 391430
| - | EventData |
An error occurred invoking the Report Definition Customization Extension (RDCE). (rsRdceInvalidCacheOptionError) An error occurred invoking the Report Definition Customization Extension (RDCE). (rsRdceInvalidCacheOptionError) Microsoft.Reporting.WinForms.ReportServerException at Microsoft.Reporting.WinForms.ServerReport.ServerUrlRequest(Boolean isAbortable, String url, Stream outputStream, String& mimeType, String& fileNameExtension) at Microsoft.Reporting.WinForms.ServerReport.InternalRender(Boolean isAbortable, String format, String deviceInfo, NameValueCollection urlAccessParameters, Stream reportStream, String& mimeType, String& fileNameExtension) at Microsoft.Reporting.WinForms.AsyncMainStreamRenderingOperation.RenderServerReport(ServerReport report) at Microsoft.Reporting.WinForms.AsyncRenderingOperation.PerformOperation() at Microsoft.Reporting.WinForms.ReportViewer.AsyncReportOperationWrapper.PerformOperation() at Microsoft.Reporting.WinForms.ProcessingThread.ProcessThreadMain(Object arg) For more information about this error navigate to the report server on the local server machine, or enable remote errors Microsoft.Reporting.WinForms.ReportServerException thanks Sachin chauhan |
| - | System |
- Provider
- EventID 1000
[ Qualifiers] 0
Level 2
Task 0
- TimeCreated
| - | EventData |
Try restarting your AOS service and SQL Reporting Services.
Is the report running on VS??
Yes, its running.
Check this link if it might solve your issue.
