SSRS Report - Field token is invalid
Assalamu Alaikum
I am very new to Dynamics AX 2012. I try to build a report just change the layout design using the existing report journal ledger, I try to build the report in Visual Studio I get the following error,
\SSRS Reports\Reports\LedgerJournal_Jbr : error AX3026: : Field token Parameters!ShowAccrualTrans.Value is invalid. Could not find the identifier.
anybody can help in this?
regards,
Mohammed Abdul Jabbar
HI Alaikum,
May be this is the refresh issue.
First check parameters, if any parameters are duplicated or any mandatory.
when you redesign you miss any fields check once.
Note: please run VS as admin.
Suresh
