Hi
I would like to print my sales order invoice as batch process. I’m able to print it manually. but when i try to schedule it as batch, i get errors.
I did the following things before running my batch.
- Created New Configuration entry (in both Server & Client Configuration Utility) with same name and TCP/IP Port as “2712”
- Checked “Connect to printers on the Server” - Client Configuration Utility
- Checked “Allow clients to connect to printers on this Server” - Server Configuration Utility
- Configured to a network printer & Outlook Email Client.
- AOS service (Dynamics AX Object Server 5.0$01-DynamicsAx1) runs by using “Admistrator” login credentials.
- When I do “Post Invoice” maually, I’m able to PRINT, EMAIL, POST TO FILE without any issue
Once my batch is done, the Sales Order Status is changed to “Invoiced” as expected, but got printing errors.
Could someone help me what is the issue?
I’m using Dynamics AX 2009 (5.0) version
Jeff
