Hi
Im quite new to Dynamics AX and we use AX-2009 in Virtual PC for Development.
I’m trying to do Sales order- Invoice as Batch processing. My objective is
to print the Sales Order > Invoice as Batch process in terms of EMail / File
/ Printer
I use my local Virtual PC machine as both AX Client and AOS Batch Server.
To print batch, I setup following things.
I set “Server Configuration”, “Batch Groups” under Administration > Setup
And as per help, I set “Connect to printers on this server” properties
both in Dynamics AX 2009 client and server configuration utility.
Whenever the batch process runs, I got the following errors on different
scenarios.
- When configured the printer for Email, the InfoLog shows the below
error
Error: Method ‘send’ in COM object of class ‘CDO.Message’ returned error code 0x80040211 () which means: .
- When configured the printer for File, the InfoLog shows the below error
Error: “Target file must be in UNC format.”
- When configured the printer to my local Printer got the error saying
Error: “Selected printer is not an AOS printer”
Am I missing something?
Could someone please assist me in this regard?
Thanks in advance
Jaff
