HI all,
I am using NAV 2015 web client and I cannot add fields using choose column in web browser. Even I cannot find “choose columns” option in web client.
Please help me to solve this issue.
Thank you.
Dinz
HI all,
Thank you.
Dinz
try to add the column in the windows client (rtc). then check if it is shown in the web client.
Hi Jonathan,
Thank you for reply,
Ya its true, it works when I add column from RTC in the server, But it works only for my login. When I add column from RTC in server and log to NAV web client (same server) by another user it again display default columns. that is the problem
Thank you.
Dinz
layout settings, set in the rtc client, are per user settings, not global settings.
other option: edit the page (or the subpage for the rows) in the dev.env. and set the importance property of that field to standard (actual value is additional, i think). that should set the visibility for all users.
Hi Jonathan,
I have checked the page layout and Importance property of that column ! it is already in standard. I will change the property to additional and get back to you.
Thank you.
Dinz
