Hi, Perhaps someone can help me.
In the webclient NAV2013 I cant remove or change my columns thats OK, but how do I change this? I tried to find infomation on MS but I couldnt find anything good. Can someone explain how to do this ?
Thanks in advance Annika
Welcome to DUG.
You have to development part on Development Environment.
Whatever changes you made on Pages will take effect in Web Client also…
Ok but if I don’t want to se example, the column Periodic Starting Date on the Web client, but on the RTC client I want to se this column. Can’t I do this ?
(I’m not a developer just a consultant [:)] )
Thee is a function called “IsWebClient” in CodeUnit 419 - File Management in NAV2013R2 but not in NAV2013.
Not sure whether you can use/redesign it in NAV2013
I just tested high level and it was working fine.
You can same same function to identify which client are you using and show the field…
Thanks, I will download the R2 and try
Thanks again
