What can i do to apply to different filters departments from different accounts within the financial statements. urgently
Hi ernst, If you go to the Field Department code totalling you can specify the dimension values for which you want the figures calculated (try using help there) or else after you use the overview function you can specify the filters on the Dimension filters tab. You can also attach an analysis view to the account shedule. regards
