Currently my customer is using navision version 4.03, and on the above menu path, after I choose account schedule and choose the overview from the below button of account schedule, I am in the overview of account schedule, where by I can see three tabs like General, Dimension Filters and Options.
Under Dimension Filters tab, I can see 4 fields, Dimension Filter 1, Dim Filter 2, Dim Filter 3 and Dim Filter 4. I can only use Dim Filter 1 and 2, Dim Filter 3 and 4 are greyoff. So I used Cntl+F2 to go into design mode of the form, choose the Dim filter 3 or 4, check their properties, they all are set as Visible, Enable, etc.
But how to make use of these two dimension filters which are called as Dim Filter 3 and Dim Filter 4
Regards
Khan
