Has anyone migrated their Navision database to the latest o/s. I know Microsoft have stated that all of the old MBS Navision products are not supported (see http://www.microsoft.com/windowsserver2003/evaluation/suppapps/appdetails.mspx) but I wondered if anyone had tried anyway?
Does anyone is running Navision Server 2.60 on a Win2003 Operating System ? Does 2.60 is Win2003 compatible ?
I’ve installed 1.2 navision on 2003 server and it worked. One of our client is installing the 2.6 on 2003 and they running into this problem, Error 1920 – Will not install the Service If you’ve installed 2.6 on 2003 without a problem, let me know.
I have installed 2.6 on Win2003. But since I had no problems in doing it, I’m not sure I can help… Have you checked if your cache setting is not exceeding the 1GB limit?
Hi Nelson, Do you know where I can download installation file for version 2.60, I want to try it on Win2003 and see if it works. Thanks, Steven Hin.
You best bet is to ask it from your NSC/MBS-Partner.
I’ve used 2.6 on NT4, then 2000 and now 2003 w/o incident. Patrick Rouse Microsoft MVP - Terminal Server www.workthin.com
quote:
