Window could not start the Microsoft Dynamics AX Object Server 6.0$02 on local computer
I installed AX2012 multiple AOS instances on the Window Server 2008 R2 x64.
Then, I cannot start the second AOS instance.
Note: The second AOS instance has TCP/IP, Service WSDL and Service endpoint ports different than the first AOS instance.
Can someone help and give me some hints?
Many thanks in advance.
-Edwin
