hi everyone,
maybe someone had asked this qs b4 i have created and posted so many sales order in my local production database, however there’snt any entry/ records in my analysis view table… does someone/ anyone have this encounter before?
hi everyone,
Did you try by running Adjust Cost - Item Entries batch job?
Have checked if the field “Update on posting” on the analysis card has been set?
If not, then you need to use the “Update” function for the analysis view.
hi ernst,
thanks for replying, i checked my live database, “update on posting” wasnt "checked’ but still there’s data in analysis view entry table
hi mohana,
thanks again for the reply… am trying to adjust the costs for now still its still processing… basically what does adjust item costs does ?
hi mohana,
unfortunately, after running adjust costs there isnt any data in my analysis view entry table also
As per Erik’s suggestion,did you try by updaing analysis views?
Report 84 - Update Analysis Views
i run it manually, select appropriate dimensions already, still no records in analysis view entry
hi all,
the problem resolved already,
what i did, i went to the end table, amend the last update number> re-run report 84 as suggested… [:D]
