Hi expert,
After post the SO, Sales Order table will delete this record and copy into shipment table. My question is I add some fields in the Sales Header table and I need those records to check but I forgot create same fields in shipment table. so does anybody knows how to retrieve the history data ?
Which version of NAV you are using ??
Have you enable archive setup to archive the sales order ?
Are you posting Shipment & Invoice from Sales order screen ?
As if your are posting only shipment then the sales order will be remain there but if you are using ship & invoice option then it will get deleted from sales order screen.
If you have enables archive setup then it will get archive.
