hi all,
iam working in first time of quality management in ax. iam studed in many times but quality parameters are where it is mentioned in quality order form.
srinivasareddy.k
hi all,
srinivasareddy.k
Hello Srinivasareddy, to start using quality control you need first to go to:
Stock management\Setup\Parameters> Quality management tab, Use quality management (check)
The other parameters setting will be find under Stock management\Setup\Quality control and Quality management
thank u
