I would like to know, where is the personal configuration data saved. For example in most cases you can change the view in Dynamics AX. You can change the position of the colomns and the save this view.
Other users are then able to call and use this view. As it’s possible to save this configuration in every module, I would like to know, whether this information is stored in a common table or in different tables for each modules.
It is stored in a common system table called “SysLastValue”. You won’t see the table in the AOT because it’s a system table, but you can still browse it if you do it via a different method.
Go to forms>SysLastValue, then go to the datasources, and right click on the SysLastValue datasource, go to “Add Ins” then table browser. The “Value” field is a container that stores “packed” data for each form and is unique throughout the system.
