when my nav2009 connect the mssql database on another machine, the webservice can’t publish success.
and when i open the url: http://machinename:7047/DynamicsNAV/WS/Services, my webservice is not here.
please help me, thanks a lot and a lot.
is your Microsoft Dynamics NAV Business Web Services started in serveR?
yes, i’m sure that the service is running, and when i connect local mssql db, the webservice can be published right.
thanks for you suggest.
can you be able to connet your database from classic in another machine?
what is the setup in Log on tab of webservice?
Did you ever find a solution to your problem? If you did, would you mind sharing it with us and if any of the posted answers helped you on the way, then please verify them.
Thank you.
