Config ur C# application on iis make sure that that iis has live ip. like website has. and on more thing whil configaration disable all the authentication… ssl certificate required…
after this just type in browser :http://UR_IP:Port
I assume your are running two services on same machine and same time.can you try this way?
Stop all of your nav service.
2.Start your new nav service.
3.Start your previous nav service.
You need to check how many nav sever folder in .\60\server. You need to recreate service again if you see only one folder when you running two service. Above solution is not work pas your event log in here.
thanks a bunch for reply have get done with some R&D now both services are working fine.
have few more things to do
through this web service I am not able to move the transaction details via transaction serve though have done the complete set. interesting part when I do one transaction in HO POS level Ii am getting a small kind of pop up saying that “Transaction header is sending” same if cross checked in store I am not able it visible in the sense its not moving
2)have done RTC POS Configuration if yes could you help me out by send the source document for the RTC Configuration it will be a great helpful to me if have replied
