I found a working solution that is use a redirect in a file but, because I think this is a common issue, I’d like to understand what is the best solution.
I was thinking also to create a rule in the IIS configuration (rewrite or redirect).
Personally I would not want to expose my NAV system this way. Even if the domain name was only inside an intranet. And I don’t think that it would be too much an issue, if they first have to go to the root, and click a link there.
If I was to do this, then I would either create an html redirect in the root /default.html or use a sub domain and DNS to redirect like nav.website.com → www.website.com/DynamicsNAV71/Webclient. Not a very slick solution either! [;)]
But please share your solution with redirect, just to know what you’ve tried already.
Thanks for your reply. I haven’t considered the possibility to do this from the DNS being myself not ad Administrator of their network.
I thought more to IIS configuration or NAV configuration.
My solution is a file Default.htm in the root of the virtualdirectory that is my domain http://www.website.com/ having in the a metatag <META http-equiv="refresh" content="0;URL=http://www.website.com/DynamicsNAV71/WebClient/"> and a link in the body.
I haven’t understood your comment about the security, probably it was because I wrote http rather than https and I haven’t said if is published over internet or intranet.
I totally agree that use a link was not a much an issue but when the customer asks something I try to please him.
