When I try to make a backup ,I got one error message at 95% completion of the backup time,the error message is “There is corrupted area in the data base.This type of error occurif the data base file is changed by the anotherprogram or if the device driver doesn’t work function correctly” .
“very very urgent problems” are solved by calling paid Microsoft Support. Anil, your’e not a newbie here, so should know…
Besides, you was in a such big hurry, that forgot to mention WHAT DB it is.
Should be Native, as with MSSQL such problems normally doesn’t arise. If it is so, try “Test database” at maximum options.
