In the Fresh Environment, I have restored the R2 backup databases in sql 2012… When i tried to install database component alone through the AX 2012 R3 setup, i finished with the Following Error… Please Help me with that and Thanks in advance…
=== Setup logging started: 02-Feb-17 12:42:14 PM ===
Running file: “C:\Program Files\Microsoft Dynamics AX\60\SetupSupport\AxSetup.exe” RelatedFilesDir=“D:\AX 2012 R3\AX2012 R3 SETUP” AutoRun=1 Location=" 313,16" LogDir=“C:\Program Files\Microsoft Dynamics AX\60\Setup Logs\2017-02-02 12-42-05”
AxSetup version number: 6.3.3000.111
Microsoft Windows NT 6.2.9200.0 (64 bit)
CONNECT1
CONNECTAXR3\Administrator
Interactive: True
2017-02-02 12:42:14Z RelatedFilesDir=D:\AX 2012 R3\AX2012 R3 SETUP
2017-02-02 12:42:14Z Location= 313,16
2017-02-02 12:42:14Z LogDir=C:\Program Files\Microsoft Dynamics AX\60\Setup Logs\2017-02-02 12-42-05
2017-02-02 12:42:14Z Property RelatedFilesDir set to: ‘D:\AX 2012 R3\AX2012 R3 SETUP’
2017-02-02 12:42:14Z Property LogDir set to: ‘C:\Program Files\Microsoft Dynamics AX\60\Setup Logs\2017-02-02 12-42-05’
2017-02-02 12:42:14Z Common Property Install Path set to ‘C:\Program Files\Microsoft Dynamics AX\60’.
2017-02-02 12:42:14Z Installation Path retrieved from registry. Value: ‘C:\Program Files\Microsoft Dynamics AX\60’
2017-02-02 12:42:14Z Initializing log file: C:\Program Files\Microsoft Dynamics AX\60\Setup Logs\2017-02-02 12-42-05\DynamicsSetupLog.txt
2017-02-02 12:42:14Z === Starting evaluation of existing installation state ===
2017-02-02 12:42:14Z MSI file: Components64.msi Installed: False
2017-02-02 12:42:14Z MSI file: HelpServer64.msi Installed: False
2017-02-02 12:42:14Z MSI file: ClientOba64.msi Installed: False
2017-02-02 12:42:14Z MSI file: TraceParser.msi Installed: False
2017-02-02 12:42:14Z MSI file: RapidStartConnectorService.msi Installed: False
2017-02-02 12:42:15Z MSI file: DIXF_AOS64.msi Installed: False
2017-02-02 12:42:15Z MSI file: DIXF_Service64.msi Installed: False
2017-02-02 12:42:15Z MSI file: DIXF_Client64.msi Installed: False
2017-02-02 12:42:15Z MSI file: AxVssWriter64.msi Installed: False
2017-02-02 12:42:15Z MSI file: Connector.msi Installed: False
2017-02-02 12:42:15Z MSI file: MRClient64.msi Installed: False
2017-02-02 12:42:15Z MSI file: MRServer64.msi Installed: False
2017-02-02 12:42:16Z MSI file: vstools64.msi Installed: False
2017-02-02 12:42:16Z Property Location set to: ‘{X=313,Y=16}’
2017-02-02 12:42:16Z === Starting UI phase ===
2017-02-02 12:42:16Z S060RetailEssentialsOption
2017-02-02 12:42:19Z Property RunMode set to: ‘Custom’
2017-02-02 12:42:19Z S070RunModeOption
2017-02-02 12:42:19Z Property BypassWarnings set to: ‘0’
2017-02-02 12:42:21Z Property RunMode set to: ‘Custom’
2017-02-02 12:42:21Z S080FeatureOption
2017-02-02 12:42:22Z Property BypassWarnings set to: ‘0’
2017-02-02 12:42:24Z Property InstallDatabase set to: ‘1’
2017-02-02 12:42:26Z S640InitialPrerequisites
2017-02-02 12:42:26Z D:\AX 2012 R3\AX2012 R3 SETUP
2017-02-02 12:42:26Z Loading data table ‘Microsoft.Dynamics.Setup.PrereqAssembly.PRRESXMAP.xml’.
2017-02-02 12:42:26Z Loading data table ‘Microsoft.Dynamics.Setup.PrereqAssembly.PRPRCMAP.xml’.
2017-02-02 12:42:26Z Loading data table ‘Microsoft.Dynamics.Setup.PrereqAssembly.PRCAMAP.xml’.
2017-02-02 12:42:26Z Loading data table ‘Microsoft.Dynamics.Setup.PrereqAssembly.COMPPRMAP.xml’.
2017-02-02 12:42:26Z Loading data table ‘Microsoft.Dynamics.Setup.PrereqAssembly.COMPDATA.xml’.
2017-02-02 12:42:26Z Loading prerequisites for component ‘Databases’:
2017-02-02 12:42:26Z Computer restart pending
2017-02-02 12:42:26Z Microsoft .NET Framework 3.5 Service Pack 1
2017-02-02 12:42:26Z Microsoft .NET Framework 4.5
2017-02-02 12:42:26Z Adding prerequisite ‘Computer restart pending’.
2017-02-02 12:42:26Z Adding prerequisite ‘Microsoft .NET Framework 3.5 Service Pack 1’.
2017-02-02 12:42:26Z Adding prerequisite ‘Microsoft .NET Framework 4.5’.
2017-02-02 12:42:27Z D:\AX 2012 R3\AX2012 R3 SETUP
2017-02-02 12:42:27Z Components selected:
2017-02-02 12:42:27Z Databases
2017-02-02 12:42:27Z Loading prerequisites for component ‘Databases’:
2017-02-02 12:42:27Z Computer restart pending
2017-02-02 12:42:27Z Microsoft .NET Framework 3.5 Service Pack 1
2017-02-02 12:42:27Z Microsoft .NET Framework 4.5
2017-02-02 12:42:27Z Adding prerequisite ‘Computer restart pending’.
2017-02-02 12:42:27Z Adding prerequisite ‘Microsoft .NET Framework 3.5 Service Pack 1’.
2017-02-02 12:42:27Z Adding prerequisite ‘Microsoft .NET Framework 4.5’.
2017-02-02 12:42:27Z Checking the following prerequisites:
2017-02-02 12:42:27Z Performing a computer restart pending check for prerequisite ‘Computer restart pending’.
2017-02-02 12:42:27Z Check failed.
2017-02-02 12:42:27Z Resolution: Restart the computer before you install Microsoft Dynamics AX or its prerequisites.
2017-02-02 12:42:27Z For information about how the prerequisite was validated, click the View log file link. For detailed troubleshooting steps, see the troubleshooting section of the Installation Guide at go.microsoft.com/…/
2017-02-02 12:42:27Z Performing a registry value version check for prerequisite ‘Microsoft .NET Framework 3.5 Service Pack 1’.
2017-02-02 12:42:27Z Searching for a minimum version of ‘3.5.30729.1’.
2017-02-02 12:42:27Z Version found: ‘3.5.30729.4926’.
2017-02-02 12:42:27Z Check succeeded.
2017-02-02 12:42:27Z Performing a .NET version check for prerequisite ‘Microsoft .NET Framework 4.5’.
2017-02-02 12:42:27Z Checking for the existence of the registry key ‘HKEY_LOCAL_MACHINE\SoftWare\Microsoft\NET Framework Setup\NDP\v4\Full’.
2017-02-02 12:42:28Z Success
2017-02-02 12:42:28Z Searching for a minimum version of ‘4.0.30319.0’.
2017-02-02 12:42:28Z Version found: ‘4.5.51641.0’.
2017-02-02 12:42:28Z Check succeeded.
2017-02-02 12:42:28Z Checking for the existence of the registry key ‘HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft.NetFramework\v4.0.30319\SKUs.NETFramework,Version=v4.5’.
2017-02-02 12:42:37Z Adding prerequisite ‘Computer restart pending’.
2017-02-02 12:42:37Z Adding prerequisite ‘Microsoft .NET Framework 3.5 Service Pack 1’.
2017-02-02 12:42:37Z Adding prerequisite ‘Microsoft .NET Framework 4.5’.
2017-02-02 12:42:37Z Checking the following prerequisites:
2017-02-02 12:42:37Z Performing a computer restart pending check for prerequisite ‘Computer restart pending’.
2017-02-02 12:42:37Z Check failed.
2017-02-02 12:42:37Z Resolution: Restart the computer before you install Microsoft Dynamics AX or its prerequisites.
2017-02-02 12:42:37Z For information about how the prerequisite was validated, click the View log file link. For detailed troubleshooting steps, see the troubleshooting section of the Installation Guide at go.microsoft.com/…/
2017-02-02 12:42:37Z Performing a registry value version check for prerequisite ‘Microsoft .NET Framework 3.5 Service Pack 1’.
2017-02-02 12:42:37Z Searching for a minimum version of ‘3.5.30729.1’.
2017-02-02 12:42:37Z Version found: ‘3.5.30729.4926’.
2017-02-02 12:42:37Z Check succeeded.
2017-02-02 12:42:38Z Performing a .NET version check for prerequisite ‘Microsoft .NET Framework 4.5’.
2017-02-02 12:42:38Z Checking for the existence of the registry key ‘HKEY_LOCAL_MACHINE\SoftWare\Microsoft\NET Framework Setup\NDP\v4\Full’.
2017-02-02 12:42:38Z Success
2017-02-02 12:42:38Z Searching for a minimum version of ‘4.0.30319.0’.
2017-02-02 12:42:38Z Version found: ‘4.5.51641.0’.
2017-02-02 12:42:38Z Check succeeded.
2017-02-02 12:42:38Z Checking for the existence of the registry key ‘HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft.NetFramework\v4.0.30319\SKUs.NETFramework,Version=v4.5’.
2017-02-02 12:42:43Z S161InstallModelDatabaseTypeOption
2017-02-02 12:42:46Z Property InstallDatabase set to: ‘2’
2017-02-02 12:42:46Z S163ModelSqlDatabaseNameSelection
2017-02-02 12:42:46Z Property DbSqlServer set to: ‘CONNECT1’
2017-02-02 12:42:50Z Property DbSqlDatabaseName set to: ‘MicrosoftDynamicsAX’
2017-02-02 12:42:51Z Property DbSqlModelStoreBaseline set to: ‘’
2017-02-02 12:42:51Z Property UpgradeDB set to: ‘0’
2017-02-02 12:42:51Z S620ModelSelection
2017-02-02 12:43:10Z Model Foundation Upgrade (Microsoft Corporation) not found.
2017-02-02 12:43:10Z Model Update for Foundation (Microsoft Corporation) not found.
2017-02-02 12:43:10Z Model SYP Labels (Microsoft Corporation) not found.
2017-02-02 12:43:10Z Model Update for Foundation Upgrade (Microsoft Corporation) not found.
2017-02-02 12:43:11Z Model Foundation Upgrade (Microsoft Corporation) not found.
2017-02-02 12:43:11Z Model Update for Foundation (Microsoft Corporation) not found.
2017-02-02 12:43:11Z Model SYP Labels (Microsoft Corporation) not found.
2017-02-02 12:43:11Z Model Update for Foundation Upgrade (Microsoft Corporation) not found.
2017-02-02 12:43:11Z OPTIONAL model D:\AX 2012 R3\AX2012 R3 SETUP\Models\Upgrade\FoundationUpgrade.axmodel is found.
2017-02-02 12:43:11Z OPTIONAL model D:\AX 2012 R3\AX2012 R3 SETUP\Models\Labels\FoundationLabels.axmodel is found.
2017-02-02 12:43:11Z MANDATORY model D:\AX 2012 R3\AX2012 R3 SETUP\Models\Standard\Foundation.axmodel is found.
2017-02-02 12:43:16Z A database named MicrosoftDynamicsAX_model already exists on server CONNECT1. Enter another name.
2017-02-02 12:43:16Z Applying slipstreamed update model files.
2017-02-02 12:43:16Z Following models are already installed:
2017-02-02 12:43:16Z File: N/A, Layer: Sys, Name: Foundation, Version: 6.2.158.0, Partition: N/A
2017-02-02 12:43:16Z File: N/A, Layer: Sys, Name: Foundation Labels, Version: 6.2.158.0, Partition: N/A
2017-02-02 12:43:16Z File: N/A, Layer: Usr, Name: USR Model, Version: 1.0.0.0, Partition: N/A
2017-02-02 12:43:16Z Following model files have been selected by user:
2017-02-02 12:43:16Z File: D:\AX 2012 R3\AX2012 R3 SETUP\Models\Standard\Foundation.axmodel, Layer: Sys, Name: Foundation, Version: 6.3.164.0, Partition: N/A
2017-02-02 12:43:16Z File: D:\AX 2012 R3\AX2012 R3 SETUP\Models\Upgrade\FoundationUpgrade.axmodel, Layer: Sys, Name: Foundation Upgrade, Version: 6.3.164.0, Partition: N/A
2017-02-02 12:43:16Z Following update packages will be applied:
2017-02-02 12:43:16Z D:\AX 2012 R3\AX2012 R3 SETUP\Updates\CU10
2017-02-02 12:43:16Z Emulating installation of selected model files.
2017-02-02 12:43:16Z Update model details metadata not available.
2017-02-02 12:43:16Z Emulating import of model file “D:\AX 2012 R3\AX2012 R3 SETUP\Models\Standard\Foundation.axmodel”.
2017-02-02 12:43:16Z Model file “D:\AX 2012 R3\AX2012 R3 SETUP\Models\Standard\Foundation.axmodel” is imported.
2017-02-02 12:43:16Z Emulating import of model file “D:\AX 2012 R3\AX2012 R3 SETUP\Models\Upgrade\FoundationUpgrade.axmodel”.
2017-02-02 12:43:16Z Model file “D:\AX 2012 R3\AX2012 R3 SETUP\Models\Upgrade\FoundationUpgrade.axmodel” is imported.
2017-02-02 12:43:16Z Applying update models in package “D:\AX 2012 R3\AX2012 R3 SETUP\Updates\CU10”.
2017-02-02 12:43:16Z Installed models:
2017-02-02 12:43:16Z Layer: “Sys”, name: “Foundation”, publisher “Microsoft Corporation”, version “6.2.158.0”, partition “N/A”
2017-02-02 12:43:16Z Layer: “Sys”, name: “Foundation Labels”, publisher “Microsoft Corporation”, version “6.2.158.0”, partition “N/A”
2017-02-02 12:43:17Z Layer: “Usr”, name: “USR Model”, publisher “”, version “1.0.0.0”, partition “N/A”
2017-02-02 12:43:17Z Layer: “Sys”, name: “Foundation”, publisher “Microsoft Corporation”, version “6.3.164.0”, partition “N/A”
2017-02-02 12:43:17Z Layer: “Sys”, name: “Foundation Upgrade”, publisher “Microsoft Corporation”, version “6.3.164.0”, partition “N/A”
2017-02-02 12:43:17Z Found update model(File: D:\AX 2012 R3\AX2012 R3 SETUP\Updates\CU10\Models\standard\dynamicsax2012r3-kb3102920-foundation.axmodel, Layer: Syp, Name: Update for Foundation, Version: 6.3.3000.111, Partition: Foundation)
2017-02-02 12:43:17Z Found update model(File: D:\AX 2012 R3\AX2012 R3 SETUP\Updates\CU10\Models\standard\dynamicsax2012r3-kb3102920-syplabels.axmodel, Layer: Syp, Name: SYP Labels, Version: 6.3.3000.111, Partition: SYP-Labels)
2017-02-02 12:43:17Z Found update model(File: D:\AX 2012 R3\AX2012 R3 SETUP\Updates\CU10\Models\upgrade\dynamicsax2012r3-kb3102920-foundationupgrade.axmodel, Layer: Syp, Name: Update for Foundation Upgrade, Version: 6.3.3000.111, Partition: FoundationUpgrade)
2017-02-02 12:43:17Z Evaluating applicability requirements for model file: D:\AX 2012 R3\AX2012 R3 SETUP\Updates\CU10\Models\standard\dynamicsax2012r3-kb3102920-foundation.axmodel
2017-02-02 12:43:17Z Required model (Layer: SYS, Name: Foundation, Version: 6.3.164.0) is installed: True
2017-02-02 12:43:17Z Update model file is installed: False
2017-02-02 12:43:17Z Evaluating applicability requirements for model file: D:\AX 2012 R3\AX2012 R3 SETUP\Updates\CU10\Models\standard\dynamicsax2012r3-kb3102920-syplabels.axmodel
2017-02-02 12:43:17Z Evaluating applicability requirements for model file: D:\AX 2012 R3\AX2012 R3 SETUP\Updates\CU10\Models\upgrade\dynamicsax2012r3-kb3102920-foundationupgrade.axmodel
2017-02-02 12:43:17Z Required model (Layer: SYS, Name: Foundation Upgrade, Version: 6.3.164.0) is installed: True
2017-02-02 12:43:18Z Emulating import of model file “D:\AX 2012 R3\AX2012 R3 SETUP\Updates\CU10\Models\standard\dynamicsax2012r3-kb3102920-foundation.axmodel”.
2017-02-02 12:43:18Z Update model details metadata not available.
2017-02-02 12:43:18Z Model file “D:\AX 2012 R3\AX2012 R3 SETUP\Updates\CU10\Models\standard\dynamicsax2012r3-kb3102920-foundation.axmodel” is imported.
2017-02-02 12:43:18Z Emulating import of model file “D:\AX 2012 R3\AX2012 R3 SETUP\Updates\CU10\Models\standard\dynamicsax2012r3-kb3102920-syplabels.axmodel”.
2017-02-02 12:43:18Z Model file “D:\AX 2012 R3\AX2012 R3 SETUP\Updates\CU10\Models\standard\dynamicsax2012r3-kb3102920-syplabels.axmodel” is imported.
2017-02-02 12:43:18Z Emulating import of model file “D:\AX 2012 R3\AX2012 R3 SETUP\Updates\CU10\Models\upgrade\dynamicsax2012r3-kb3102920-foundationupgrade.axmodel”.
2017-02-02 12:43:18Z Model file “D:\AX 2012 R3\AX2012 R3 SETUP\Updates\CU10\Models\upgrade\dynamicsax2012r3-kb3102920-foundationupgrade.axmodel” is imported.
2017-02-02 12:43:18Z Following model files will be installed:
2017-02-02 12:43:18Z File: D:\AX 2012 R3\AX2012 R3 SETUP\Models\Standard\Foundation.axmodel, Layer: Sys, Name: Foundation, Version: 6.3.164.0, Partition: N/A
2017-02-02 12:43:18Z File: D:\AX 2012 R3\AX2012 R3 SETUP\Models\Upgrade\FoundationUpgrade.axmodel, Layer: Sys, Name: Foundation Upgrade, Version: 6.3.164.0, Partition: N/A
2017-02-02 12:43:18Z File: D:\AX 2012 R3\AX2012 R3 SETUP\Updates\CU10\Models\standard\dynamicsax2012r3-kb3102920-foundation.axmodel, Layer: Syp, Name: Update for Foundation, Version: 6.3.3000.111, Partition: N/A
2017-02-02 12:43:18Z File: D:\AX 2012 R3\AX2012 R3 SETUP\Updates\CU10\Models\standard\dynamicsax2012r3-kb3102920-syplabels.axmodel, Layer: Syp, Name: SYP Labels, Version: 6.3.3000.111, Partition: N/A
2017-02-02 12:43:18Z File: D:\AX 2012 R3\AX2012 R3 SETUP\Updates\CU10\Models\upgrade\dynamicsax2012r3-kb3102920-foundationupgrade.axmodel, Layer: Syp, Name: Update for Foundation Upgrade, Version: 6.3.3000.111, Partition: N/A
2017-02-02 12:43:18Z S621ModelStoreUpdate
2017-02-02 12:43:19Z A database named MicrosoftDynamicsAX_model already exists on server CONNECT1. Enter another name.
2017-02-02 12:43:28Z Property ModelStoreBackupFile set to: ‘’
2017-02-02 12:43:28Z Property ModelStoreBackupDir set to: ‘E:\TEMP STORAGE’
2017-02-02 12:43:28Z Property SynchServiceHeadOfficeDatabaseServerName set to: ‘’
2017-02-02 12:43:28Z Property SynchServiceHeadOfficeDatabase set to: ‘’
2017-02-02 12:43:28Z Property SynchServiceClientDatabase set to: ‘’
2017-02-02 12:43:28Z Property SynchServiceClientDatabaseServerName set to: ‘’
2017-02-02 12:43:28Z Property ChannelDatabase set to: ‘’
2017-02-02 12:43:28Z Property ChannelDatabaseServer set to: ‘’
2017-02-02 12:43:28Z Property RetailServerDatabase set to: ‘’
2017-02-02 12:43:28Z Property RetailServerDatabaseServerName set to: ‘’
2017-02-02 12:43:28Z Loading prerequisites for component ‘Databases’:
2017-02-02 12:43:28Z Computer restart pending
2017-02-02 12:43:28Z Microsoft .NET Framework 3.5 Service Pack 1
2017-02-02 12:43:29Z Microsoft .NET Framework 4.5
2017-02-02 12:43:29Z Microsoft SQL Server Full-Text Search
2017-02-02 12:43:29Z SQL Server Full-text Filter Daemon Launcher service startup type
2017-02-02 12:43:29Z SQL Server Full-text Filter Daemon Launcher service started
2017-02-02 12:43:29Z Adding prerequisite ‘Computer restart pending’.
2017-02-02 12:43:29Z Adding prerequisite ‘Microsoft .NET Framework 3.5 Service Pack 1’.
2017-02-02 12:43:29Z Adding prerequisite ‘Microsoft .NET Framework 4.5’.
2017-02-02 12:43:29Z Adding prerequisite ‘Microsoft SQL Server Full-Text Search’.
2017-02-02 12:43:29Z Adding prerequisite ‘SQL Server Full-text Filter Daemon Launcher service startup type’.
2017-02-02 12:43:29Z Adding prerequisite ‘SQL Server Full-text Filter Daemon Launcher service started’.
2017-02-02 12:43:29Z Adding prerequisite ‘Microsoft SQL Server (Databases)’.
2017-02-02 12:43:29Z S630Prerequisites
2017-02-02 12:43:29Z D:\AX 2012 R3\AX2012 R3 SETUP
2017-02-02 12:43:29Z Components selected:
2017-02-02 12:43:29Z Databases
2017-02-02 12:43:29Z Loading prerequisites for component ‘Databases’:
2017-02-02 12:43:29Z Computer restart pending
2017-02-02 12:43:29Z Microsoft .NET Framework 3.5 Service Pack 1
2017-02-02 12:43:30Z Microsoft SQL Server Full-Text Search
2017-02-02 12:43:30Z SQL Server Full-text Filter Daemon Launcher service startup type
2017-02-02 12:43:30Z SQL Server Full-text Filter Daemon Launcher service started
2017-02-02 12:43:30Z Adding prerequisite ‘Computer restart pending’.
2017-02-02 12:43:30Z Adding prerequisite ‘Microsoft .NET Framework 3.5 Service Pack 1’.
2017-02-02 12:43:30Z Adding prerequisite ‘Microsoft .NET Framework 4.5’.
2017-02-02 12:43:30Z Adding prerequisite ‘Microsoft SQL Server Full-Text Search’.
2017-02-02 12:43:30Z Adding prerequisite ‘SQL Server Full-text Filter Daemon Launcher service startup type’.
2017-02-02 12:43:30Z Adding prerequisite ‘SQL Server Full-text Filter Daemon Launcher service started’.
2017-02-02 12:43:30Z Adding prerequisite ‘Microsoft SQL Server (Databases)’.
2017-02-02 12:43:30Z Checking the following prerequisites:
2017-02-02 12:43:30Z Performing a computer restart pending check for prerequisite ‘Computer restart pending’.
2017-02-02 12:43:30Z Check failed.
2017-02-02 12:43:30Z Resolution: Restart the computer before you install Microsoft Dynamics AX or its prerequisites.
2017-02-02 12:43:30Z For information about how the prerequisite was validated, click the View log file link. For detailed troubleshooting steps, see the troubleshooting section of the Installation Guide at go.microsoft.com/…/
2017-02-02 12:43:30Z Performing a registry value version check for prerequisite ‘Microsoft .NET Framework 3.5 Service Pack 1’.
2017-02-02 12:43:30Z Searching for a minimum version of ‘3.5.30729.1’.
2017-02-02 12:43:30Z Version found: ‘3.5.30729.4926’.
2017-02-02 12:43:30Z Check succeeded.
2017-02-02 12:43:30Z Performing a .NET version check for prerequisite ‘Microsoft .NET Framework 4.5’.
2017-02-02 12:43:30Z Checking for the existence of the registry key ‘HKEY_LOCAL_MACHINE\SoftWare\Microsoft\NET Framework Setup\NDP\v4\Full’.
2017-02-02 12:43:30Z Success
2017-02-02 12:43:30Z Searching for a minimum version of ‘4.0.30319.0’.
2017-02-02 12:43:30Z Version found: ‘4.5.51641.0’.
2017-02-02 12:43:30Z Checking for the existence of the registry key ‘HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft.NetFramework\v4.0.30319\SKUs.NETFramework,Version=v4.5’.
2017-02-02 12:43:30Z Performing a service existence check for prerequisite ‘Microsoft SQL Server Full-Text Search’.
2017-02-02 12:43:30Z Checking for the existence of the service ‘MSSQLFDLauncher’ on the machine ‘CONNECT1’.
2017-02-02 12:43:30Z Performing a service status check for prerequisite ‘SQL Server Full-text Filter Daemon Launcher service startup type’.
2017-02-02 12:43:30Z Checking the startup type of the service ‘CONNECT1’ on the machine ‘MSSQLFDLauncher’.
2017-02-02 12:43:31Z Found: ‘Automatic’ Expected: ‘Automatic’.
2017-02-02 12:43:31Z Success
2017-02-02 12:43:31Z Check succeeded.
2017-02-02 12:43:31Z Performing a service status check for prerequisite ‘SQL Server Full-text Filter Daemon Launcher service started’.
2017-02-02 12:43:31Z Checking the status of the service ‘MSSQLFDLauncher’ on the machine ‘CONNECT1’.
2017-02-02 12:43:31Z Performing a database version check for prerequisite ‘Microsoft SQL Server (Databases)’.
2017-02-02 12:43:31Z Attempting to connect to SQL Server ‘CONNECT1’.
2017-02-02 12:43:31Z Searching for a minimum version of ‘10.0.2531.0’.
2017-02-02 12:43:31Z Version found: ‘11.0.2100.0’.
2017-02-02 12:43:31Z Adding prerequisite ‘Computer restart pending’.
2017-02-02 12:43:31Z Adding prerequisite ‘Microsoft .NET Framework 3.5 Service Pack 1’.
2017-02-02 12:43:31Z Adding prerequisite ‘Microsoft .NET Framework 4.5’.
2017-02-02 12:43:31Z Adding prerequisite ‘Microsoft SQL Server Full-Text Search’.
2017-02-02 12:43:31Z Adding prerequisite ‘SQL Server Full-text Filter Daemon Launcher service startup type’.
2017-02-02 12:43:31Z Adding prerequisite ‘SQL Server Full-text Filter Daemon Launcher service started’.
2017-02-02 12:43:31Z Adding prerequisite ‘Microsoft SQL Server (Databases)’.
2017-02-02 12:43:36Z S240LastInfo
2017-02-02 12:43:40Z S250InstallProgressInfo
2017-02-02 12:43:40Z === Starting execution phase ===
2017-02-02 12:43:40Z Executing ‘Databases’ this pass.
2017-02-02 12:43:40Z Queueing for installation: Databases
2017-02-02 12:43:40Z Component installation task completed successfully.
2017-02-02 12:43:40Z === Setting up Update model store ===
2017-02-02 12:43:40Z A database named MicrosoftDynamicsAX_model already exists on server CONNECT1. Enter another name.
2017-02-02 12:43:40Z === Setting up MicrosoftDynamicsAX_UpgradeR3Baseline ===
2017-02-02 12:43:42Z Completed setup of MicrosoftDynamicsAX_UpgradeR3Baseline.
2017-02-02 12:43:51Z Executing AxUtil Schema for database ‘CONNECT1\MicrosoftDynamicsAX_model’.
2017-02-02 12:44:05Z Exporting CONNECT1\MicrosoftDynamicsAX_model to file E:\TEMP STORAGE\AxModelStoreUpgradeBackup63.axmodelbak
2017-02-02 12:45:48Z Failed to export model store
2017-02-02 12:45:48Z Completed setup of MicrosoftDynamicsAX_model.
2017-02-02 12:45:48Z Executing AxUtil Schema for database ‘CONNECT1\MicrosoftDynamicsAX_model’.
2017-02-02 12:46:01Z Ignored:
2017-02-02 12:46:01Z Model Foundation Upgrade (Microsoft Corporation) not found.
2017-02-02 12:46:01Z Importing file ‘D:\AX 2012 R3\AX2012 R3 SETUP\Models\Standard\Foundation.axmodel’ to the database ‘CONNECT1\MicrosoftDynamicsAX_model’.
2017-02-02 12:46:01Z Importing file ‘D:\AX 2012 R3\AX2012 R3 SETUP\Models\Upgrade\FoundationUpgrade.axmodel’ to the database ‘CONNECT1\MicrosoftDynamicsAX_model’.
2017-02-02 12:46:01Z Model ‘Foundation’ will be replaced.
2017-02-02 12:46:01Z Executing the following AxUtil command:axutil.exe import /noprompt /file:“D:\AX 2012 R3\AX2012 R3 SETUP\Models\Standard\Foundation.axmodel”,“D:\AX 2012 R3\AX2012 R3 SETUP\Models\Upgrade\FoundationUpgrade.axmodel” /conflict:“Push” /replace:“Foundation” /db:“MicrosoftDynamicsAX_model” /s:“CONNECT1”
2017-02-02 15:10:37Z ******************************************************************************************************
2017-02-02 15:10:37Z A severe error occurred on the current command. The results, if any, should be discarded.
2017-02-02 15:10:37Z One or more model elements in the imported model file contains
2017-02-02 15:10:37Z elements that have a different name in the model store. The following elements
2017-02-02 15:10:37Z have been renamed during import:
2017-02-02 15:10:37Z Model import resulted in an error. See previous log messages for details.
2017-02-02 15:10:46Z Applying slipstreamed update model files.
2017-02-02 15:10:46Z Following models are already installed:
2017-02-02 15:10:46Z File: N/A, Layer: Sys, Name: Foundation, Version: 6.2.158.0, Partition: N/A
2017-02-02 15:10:46Z File: N/A, Layer: Sys, Name: Foundation Labels, Version: 6.2.158.0, Partition: N/A
2017-02-02 15:10:46Z File: N/A, Layer: Usr, Name: USR Model, Version: 1.0.0.0, Partition: N/A
2017-02-02 15:10:46Z Following model files have been selected by user:
2017-02-02 15:10:46Z Following update packages will be applied:
2017-02-02 15:10:46Z D:\AX 2012 R3\AX2012 R3 SETUP\Updates\CU10
2017-02-02 15:10:46Z Emulating installation of selected model files.
2017-02-02 15:10:46Z Applying update models in package “D:\AX 2012 R3\AX2012 R3 SETUP\Updates\CU10”.
2017-02-02 15:10:46Z Installed models:
2017-02-02 15:10:46Z Layer: “Sys”, name: “Foundation”, publisher “Microsoft Corporation”, version “6.2.158.0”, partition “N/A”
2017-02-02 15:10:46Z Layer: “Sys”, name: “Foundation Labels”, publisher “Microsoft Corporation”, version “6.2.158.0”, partition “N/A”
2017-02-02 15:10:46Z Layer: “Usr”, name: “USR Model”, publisher “”, version “1.0.0.0”, partition “N/A”
2017-02-02 15:10:46Z Found update model(File: D:\AX 2012 R3\AX2012 R3 SETUP\Updates\CU10\Models\standard\dynamicsax2012r3-kb3102920-foundation.axmodel, Layer: Syp, Name: Update for Foundation, Version: 6.3.3000.111, Partition: Foundation)
2017-02-02 15:10:47Z Found update model(File: D:\AX 2012 R3\AX2012 R3 SETUP\Updates\CU10\Models\standard\dynamicsax2012r3-kb3102920-syplabels.axmodel, Layer: Syp, Name: SYP Labels, Version: 6.3.3000.111, Partition: SYP-Labels)
2017-02-02 15:10:47Z Found update model(File: D:\AX 2012 R3\AX2012 R3 SETUP\Updates\CU10\Models\upgrade\dynamicsax2012r3-kb3102920-foundationupgrade.axmodel, Layer: Syp, Name: Update for Foundation Upgrade, Version: 6.3.3000.111, Partition: FoundationUpgrade)
2017-02-02 15:10:47Z Evaluating applicability requirements for model file: D:\AX 2012 R3\AX2012 R3 SETUP\Updates\CU10\Models\standard\dynamicsax2012r3-kb3102920-foundation.axmodel
2017-02-02 15:10:47Z Required model (Layer: SYS, Name: Foundation, Version: 6.3.164.0) is installed: False
2017-02-02 15:10:47Z Evaluating applicability requirements for model file: D:\AX 2012 R3\AX2012 R3 SETUP\Updates\CU10\Models\standard\dynamicsax2012r3-kb3102920-syplabels.axmodel
