Greetings, kindly i face issue in first step in upgrade to connect with exist database to import R2 models ,indeed before this I escaped some step in upgrade code
First step :-
As in-place Technet document mention removed all model contents on “Upgrade” i removed it , and first step in upgrade code required import model for upgrade and i do not have model to import , or i do not know what is required in this steps?.
Second step:-
I escaped also upload license, is it important upload it again? i am already have a valid license on current AX 2012 FP instance.
i do not know is it the reason in failure the step or not and in below the setup log file
=== Setup logging started: 12/25/2013 10:19:59 PM ===
Running file: “C:\Program Files\Microsoft Dynamics AX\60\SetupSupport\AxSetup.exe” RelatedFilesDir=“D:\AX R2” AutoRun=1 LogDir=“C:\Program Files\Microsoft Dynamics AX\60\Setup Logs\2013-12-25 22-19-57”
AxSetup version number: 6.2.158.0
Microsoft Windows NT 6.1.7601 Service Pack 1 (64 bit)
DR-SQL-S01
SSNB\axadmin
Interactive: True
2013-12-25 22:19:59Z RelatedFilesDir=D:\AX R2
2013-12-25 22:19:59Z LogDir=C:\Program Files\Microsoft Dynamics AX\60\Setup Logs\2013-12-25 22-19-57
2013-12-25 22:19:59Z Property RelatedFilesDir set to: ‘D:\AX R2’
2013-12-25 22:19:59Z Property LogDir set to: ‘C:\Program Files\Microsoft Dynamics AX\60\Setup Logs\2013-12-25 22-19-57’
2013-12-25 22:19:59Z Common Property Install Path set to ‘C:\Program Files\Microsoft Dynamics AX\60’.
2013-12-25 22:19:59Z Installation Path retrieved from registry. Value: ‘C:\Program Files\Microsoft Dynamics AX\60’
2013-12-25 22:19:59Z Initializing log file: C:\Program Files\Microsoft Dynamics AX\60\Setup Logs\2013-12-25 22-19-57\DynamicsSetupLog.txt
2013-12-25 22:19:59Z === Starting evaluation of existing installation state ===
2013-12-25 22:20:00Z MSI file: Components64.msi Installed: False
2013-12-25 22:20:00Z MSI file: HelpServer64.msi Installed: False
2013-12-25 22:20:00Z MSI file: ClientOba64.msi Installed: False
2013-12-25 22:20:00Z MSI file: TraceParser.msi Installed: False
2013-12-25 22:20:00Z MSI file: RapidStartConnectorService.msi Installed: False
2013-12-25 22:20:00Z === Starting UI phase ===
2013-12-25 22:20:02Z S030WelcomeInfo
2013-12-25 22:20:06Z S070RunModeOption
2013-12-25 22:20:06Z Property BypassWarnings set to: ‘0’
2013-12-25 22:20:08Z Property RunMode set to: ‘Custom’
2013-12-25 22:20:13Z S080FeatureOption
2013-12-25 22:20:14Z Property BypassWarnings set to: ‘0’
2013-12-25 22:20:17Z Property InstallDatabase set to: ‘1’
2013-12-25 22:20:21Z S640InitialPrerequisites
2013-12-25 22:20:22Z Loading data table ‘Microsoft.Dynamics.Setup.PrereqAssembly.PRRESXMAP.xml’.
2013-12-25 22:20:22Z Loading data table ‘Microsoft.Dynamics.Setup.PrereqAssembly.PRPRCMAP.xml’.
2013-12-25 22:20:22Z Loading data table ‘Microsoft.Dynamics.Setup.PrereqAssembly.PRCAMAP.xml’.
2013-12-25 22:20:22Z Loading data table ‘Microsoft.Dynamics.Setup.PrereqAssembly.COMPPRMAP.xml’.
2013-12-25 22:20:22Z Loading data table ‘Microsoft.Dynamics.Setup.PrereqAssembly.COMPDATA.xml’.
2013-12-25 22:20:22Z Loading prerequisites for component ‘Databases’:
2013-12-25 22:20:22Z Computer restart pending
2013-12-25 22:20:22Z Microsoft .NET Framework 3.5 Service Pack 1
2013-12-25 22:20:22Z Adding prerequisite ‘Computer restart pending’.
2013-12-25 22:20:22Z Adding prerequisite ‘Microsoft .NET Framework 3.5 Service Pack 1’.
2013-12-25 22:20:22Z D:\AX R2
2013-12-25 22:20:22Z Components selected:
2013-12-25 22:20:22Z Databases
2013-12-25 22:20:22Z Checking the following prerequisites:
2013-12-25 22:20:22Z Performing a computer restart pending check for prerequisite ‘Computer restart pending’.
2013-12-25 22:20:22Z Check succeeded.
2013-12-25 22:20:22Z Performing a registry value version check for prerequisite ‘Microsoft .NET Framework 3.5 Service Pack 1’.
2013-12-25 22:20:22Z Searching for a minimum version of ‘3.5.30729.1’.
2013-12-25 22:20:22Z Version found: ‘3.5.30729.5420’.
2013-12-25 22:20:24Z S161InstallModelDatabaseTypeOption
2013-12-25 22:20:32Z Property InstallDatabase set to: ‘2’
2013-12-25 22:20:32Z S163ModelSqlDatabaseNameSelection
2013-12-25 22:20:32Z Property DbSqlServer set to: ‘DR-SQL-S01’
2013-12-25 22:20:43Z Property DbSqlServer set to: ‘DR-SQL-S01\AX’
2013-12-25 22:20:56Z Property DbSqlDatabaseName set to: ‘SAPreproduction’
2013-12-25 22:20:56Z Property DbSqlModelStoreBaseline set to: ‘’
2013-12-25 22:20:56Z Property UpgradeDB set to: ‘0’
2013-12-25 22:20:56Z S620ModelSelection
2013-12-25 22:21:32Z The database SAPreproduction_model does not exist.
2013-12-25 22:21:33Z OPTIONAL model D:\AX R2\Models\Labels\FoundationLabels.axmodel is found.
2013-12-25 22:21:33Z MANDATORY model D:\AX R2\Models\Standard\Foundation.axmodel is found.
2013-12-25 22:21:33Z OPTIONAL model D:\AX R2\Models\Upgrade\FoundationUpgrade.axmodel is found.
2013-12-25 22:21:59Z ******************************************************************************************************
2013-12-25 22:21:59Z The database SAPreproduction_model does not exist.
2013-12-25 22:22:02Z Applying slipstreamed update model files.
2013-12-25 22:22:02Z Following models are already installed:
2013-12-25 22:22:02Z File: N/A, Layer: Sys, Name: Foundation, Version: 6.0.947.0, Partition: N/A
2013-12-25 22:22:02Z File: N/A, Layer: Syp, Name: Update for Foundation, Version: 6.0.1108.670, Partition: N/A
2013-12-25 22:22:02Z File: N/A, Layer: Syp, Name: SYP Labels, Version: 6.0.1108.670, Partition: N/A
2013-12-25 22:22:02Z File: N/A, Layer: Fpk, Name: Extensions, Version: 6.1.1108.0, Partition: N/A
2013-12-25 22:22:02Z File: N/A, Layer: Fpp, Name: FPP Labels, Version: 6.0.1108.670, Partition: N/A
2013-12-25 22:22:02Z File: N/A, Layer: Fpp, Name: Update for Extensions, Version: 6.1.1108.670, Partition: N/A
2013-12-25 22:22:02Z File: N/A, Layer: Var, Name: VAR Model, Version: 1.0.0.0, Partition: N/A
2013-12-25 22:22:02Z File: N/A, Layer: Var, Name: NTPay, Version: 1.0.0.0, Partition: N/A
2013-12-25 22:22:02Z File: N/A, Layer: Var, Name: NAP, Version: 1.0.0.0, Partition: N/A
2013-12-25 22:22:02Z File: N/A, Layer: Usr, Name: USR Model, Version: 1.0.0.0, Partition: N/A
2013-12-25 22:22:02Z Following model files have been selected by user:
2013-12-25 22:22:02Z File: D:\AX R2\Models\Standard\Foundation.axmodel, Layer: Sys, Name: Foundation, Version: 6.2.158.0, Partition: N/A
2013-12-25 22:22:02Z Following update packages will be applied:
2013-12-25 22:22:02Z Emulating installation of selected model files.
2013-12-25 22:22:02Z Update model details metadata not available.
2013-12-25 22:22:02Z Emulating import of model file “D:\AX R2\Models\Standard\Foundation.axmodel”.
2013-12-25 22:22:02Z Model file “D:\AX R2\Models\Standard\Foundation.axmodel” is imported.
2013-12-25 22:22:02Z Following model files will be installed:
2013-12-25 22:22:02Z S621ModelStoreUpdate
2013-12-25 22:22:39Z Property ModelStoreBackupDir set to: ‘C:\AX R2 Ins_Log’
2013-12-25 22:22:39Z Loading prerequisites for component ‘Databases’:
2013-12-25 22:22:39Z Computer restart pending
2013-12-25 22:22:39Z Microsoft .NET Framework 3.5 Service Pack 1
2013-12-25 22:22:39Z Microsoft SQL Server Full-Text Search
2013-12-25 22:22:39Z SQL Server Full-text Filter Daemon Launcher service startup type
2013-12-25 22:22:39Z SQL Server Full-text Filter Daemon Launcher service started
2013-12-25 22:22:39Z Adding prerequisite ‘Computer restart pending’.
2013-12-25 22:22:39Z Adding prerequisite ‘Microsoft .NET Framework 3.5 Service Pack 1’.
2013-12-25 22:22:39Z Adding prerequisite ‘Microsoft SQL Server Full-Text Search’.
2013-12-25 22:22:39Z Adding prerequisite ‘SQL Server Full-text Filter Daemon Launcher service startup type’.
2013-12-25 22:22:39Z Adding prerequisite ‘SQL Server Full-text Filter Daemon Launcher service started’.
2013-12-25 22:22:40Z Adding prerequisite ‘Microsoft SQL Server (Databases)’.
2013-12-25 22:22:40Z S630Prerequisites
2013-12-25 22:22:40Z D:\AX R2
2013-12-25 22:22:40Z Components selected:
2013-12-25 22:22:40Z Databases
2013-12-25 22:22:40Z Loading prerequisites for component ‘Databases’:
2013-12-25 22:22:40Z Computer restart pending
2013-12-25 22:22:40Z Microsoft .NET Framework 3.5 Service Pack 1
2013-12-25 22:22:40Z Microsoft SQL Server Full-Text Search
2013-12-25 22:22:40Z SQL Server Full-text Filter Daemon Launcher service startup type
2013-12-25 22:22:40Z SQL Server Full-text Filter Daemon Launcher service started
2013-12-25 22:22:40Z Adding prerequisite ‘Computer restart pending’.
2013-12-25 22:22:40Z Adding prerequisite ‘Microsoft .NET Framework 3.5 Service Pack 1’.
2013-12-25 22:22:40Z Adding prerequisite ‘Microsoft SQL Server Full-Text Search’.
2013-12-25 22:22:40Z Adding prerequisite ‘SQL Server Full-text Filter Daemon Launcher service startup type’.
2013-12-25 22:22:40Z Adding prerequisite ‘SQL Server Full-text Filter Daemon Launcher service started’.
2013-12-25 22:22:40Z Checking the following prerequisites:
2013-12-25 22:22:40Z Performing a computer restart pending check for prerequisite ‘Computer restart pending’.
2013-12-25 22:22:40Z Check succeeded.
2013-12-25 22:22:40Z Performing a registry value version check for prerequisite ‘Microsoft .NET Framework 3.5 Service Pack 1’.
2013-12-25 22:22:40Z Searching for a minimum version of ‘3.5.30729.1’.
2013-12-25 22:22:40Z Version found: ‘3.5.30729.5420’.
2013-12-25 22:22:40Z Performing a service existence check for prerequisite ‘Microsoft SQL Server Full-Text Search’.
2013-12-25 22:22:40Z Checking for the existence of the service ‘MSSQLFDLauncher’ on the machine ‘DR-SQL-S01’.
2013-12-25 22:22:40Z Success
2013-12-25 22:22:40Z Performing a service status check for prerequisite ‘SQL Server Full-text Filter Daemon Launcher service startup type’.
2013-12-25 22:22:40Z Checking the startup type of the service ‘DR-SQL-S01’ on the machine ‘MSSQLFDLauncher’.
2013-12-25 22:22:40Z Found: ‘Automatic’ Expected: ‘Automatic’.
2013-12-25 22:22:41Z Check succeeded.
2013-12-25 22:22:41Z Performing a service status check for prerequisite ‘SQL Server Full-text Filter Daemon Launcher service started’.
2013-12-25 22:22:41Z Checking the status of the service ‘MSSQLFDLauncher’ on the machine ‘DR-SQL-S01’.
2013-12-25 22:22:41Z Success
2013-12-25 22:22:41Z Performing a database version check for prerequisite ‘Microsoft SQL Server (Databases)’.
2013-12-25 22:22:41Z Attempting to connect to SQL Server ‘DR-SQL-S01\AX’.
2013-12-25 22:22:41Z Searching for a minimum version of ‘10.0.2531.0’.
2013-12-25 22:22:41Z Version found: ‘10.50.2500.0’.
2013-12-25 22:22:41Z Adding prerequisite ‘Computer restart pending’.
2013-12-25 22:22:41Z Adding prerequisite ‘Microsoft .NET Framework 3.5 Service Pack 1’.
2013-12-25 22:22:41Z Adding prerequisite ‘Microsoft SQL Server Full-Text Search’.
2013-12-25 22:22:41Z Adding prerequisite ‘SQL Server Full-text Filter Daemon Launcher service startup type’.
2013-12-25 22:22:41Z Adding prerequisite ‘SQL Server Full-text Filter Daemon Launcher service started’.
2013-12-25 22:22:41Z Adding prerequisite ‘Microsoft SQL Server (Databases)’.
2013-12-25 22:22:44Z S240LastInfo
2013-12-25 22:22:46Z S250InstallProgressInfo
2013-12-25 22:22:46Z === Starting execution phase ===
2013-12-25 22:22:46Z Executing ‘Databases’ this pass.
2013-12-25 22:22:46Z Queueing for installation: Databases
2013-12-25 22:22:46Z Component installation task completed successfully.
2013-12-25 22:22:46Z === Setting up Update model store ===
2013-12-25 22:22:46Z === Setting up Splitting model and business database ===
2013-12-25 22:22:46Z Executing AxUtil Schema for database ‘DR-SQL-S01\AX\SAPreproduction_model’.
2013-12-25 22:22:55Z Executing AxUtil Schema for database ‘DR-SQL-S01\AX\SAPreproduction’.
2013-12-25 22:23:12Z Exporting DR-SQL-S01\AX\SAPreproduction to file C:\AX R2 Ins_Log\AxModelStoreUpgradeBackup62.axmodelbak
2013-12-25 22:28:22Z === Setting up Import model store in SAPreproduction_model database ===
2013-12-25 22:28:24Z Importing DR-SQL-S01\AX\SAPreproduction_model from file C:\AX R2 Ins_Log\AxModelStoreUpgradeBackup62.axmodelbak
2013-12-25 22:37:25Z Completed setup of SAPreproduction_model.
2013-12-25 22:37:25Z Executing AxUtil Schema for database ‘DR-SQL-S01\AX\SAPreproduction_model’.
2013-12-25 22:37:33Z Importing file ‘D:\AX R2\Models\Standard\Foundation.axmodel’ to the database ‘DR-SQL-S01\AX\SAPreproduction_model’.
2013-12-25 22:37:33Z Model ‘Foundation’ will be replaced.
2013-12-25 22:37:33Z Model ‘’ will be replaced.
2013-12-25 23:02:56Z ******************************************************************************************************
2013-12-25 23:02:56Z The model contains a customization of a license code. The model cannot be imported because you can overlayer a license code from the patching layer only.
2013-12-25 23:02:56Z One or more model elements in the imported model file contains
2013-12-25 23:02:56Z elements that have a different name in the model store. The following elements
2013-12-25 23:02:56Z have been renamed during import:
2013-12-25 23:02:56Z Model import resulted in an error. See previous log messages for details.
2013-12-25 23:02:56Z Component installation task stopped due to an error.
2013-12-25 23:02:58Z S260FinishedInfo
