Hi,am installing ax2012 feature pack .When i install the database,this is the error am getting…Please help
=== Setup logging started: 05/05/2014 08:53:30 ===
Running file: “C:\Program Files\Microsoft Dynamics AX\60\SetupSupport\AxSetup.exe” RelatedFilesDir=“C:\Users\dominic.m.DIPL\Desktop\DynamicsAX_2012 Feature Pack” AutoRun=1 Location=" 316,16" LogDir=“C:\Program Files\Microsoft Dynamics AX\60\Setup Logs\2014-05-05 08-52-28”
AxSetup version number: 6.0.947.862
Microsoft Windows NT 6.2.9200.0 (64 bit)
DOMMY
DIPL\Dominic.M
Interactive: True
2014-05-05 08:53:30Z RelatedFilesDir=C:\Users\dominic.m.DIPL\Desktop\DynamicsAX_2012 Feature Pack
2014-05-05 08:53:30Z Location= 316,16
2014-05-05 08:53:30Z LogDir=C:\Program Files\Microsoft Dynamics AX\60\Setup Logs\2014-05-05 08-52-28
2014-05-05 08:53:30Z Property RelatedFilesDir set to: ‘C:\Users\dominic.m.DIPL\Desktop\DynamicsAX_2012 Feature Pack’
2014-05-05 08:53:30Z Property LogDir set to: ‘C:\Program Files\Microsoft Dynamics AX\60\Setup Logs\2014-05-05 08-52-28’
2014-05-05 08:53:30Z Common Property Install Path set to ‘C:\Program Files\Microsoft Dynamics AX\60’.
2014-05-05 08:53:30Z Installation Path retrieved from registry. Value: ‘C:\Program Files\Microsoft Dynamics AX\60’
2014-05-05 08:53:30Z Initializing log file: C:\Program Files\Microsoft Dynamics AX\60\Setup Logs\2014-05-05 08-52-28\DynamicsSetupLog.txt
2014-05-05 08:53:31Z === Starting evaluation of existing installation state ===
2014-05-05 08:53:31Z MSI file: Components64.msi Installed: False
2014-05-05 08:53:31Z MSI file: HelpServer64.msi Installed: False
2014-05-05 08:53:31Z MSI file: ClientOba64.msi Installed: False
2014-05-05 08:53:31Z MSI file: TraceParser.msi Installed: False
2014-05-05 08:53:31Z MSI file: RapidStartConnectorService.msi Installed: False
2014-05-05 08:53:31Z MSI file: RetailHeadquarters64.msi Installed: False
2014-05-05 08:53:31Z MSI file: RetailPOS.msi Installed: False
2014-05-05 08:53:31Z MSI file: RetailPOSPlugins.msi Installed: False
2014-05-05 08:53:31Z MSI file: RetailSaltUtility64.msi Installed: False
2014-05-05 08:53:31Z MSI file: RetailStoreConnect64.msi Installed: False
2014-05-05 08:53:31Z MSI file: RetailDatabaseUtility.msi Installed: False
2014-05-05 08:53:31Z MSI file: RetailTransactionService.msi Installed: False
2014-05-05 08:53:31Z Property Location set to: ‘{X=316,Y=16}’
2014-05-05 08:53:31Z === Starting UI phase ===
2014-05-05 08:53:31Z S070RunModeOption
2014-05-05 08:53:32Z Property BypassWarnings set to: ‘0’
2014-05-05 08:53:49Z Property RunMode set to: ‘Custom’
2014-05-05 08:53:52Z S080FeatureOption
2014-05-05 08:53:53Z Property BypassWarnings set to: ‘0’
2014-05-05 08:54:45Z Property InstallDatabase set to: ‘1’
2014-05-05 08:55:02Z S640InitialPrerequisites
2014-05-05 08:55:03Z Loading data table ‘Microsoft.Dynamics.Setup.PrereqAssembly.PRRESXMAP.xml’.
2014-05-05 08:55:03Z Loading data table ‘Microsoft.Dynamics.Setup.PrereqAssembly.PRPRCMAP.xml’.
2014-05-05 08:55:03Z Loading data table ‘Microsoft.Dynamics.Setup.PrereqAssembly.PRCAMAP.xml’.
2014-05-05 08:55:03Z Loading data table ‘Microsoft.Dynamics.Setup.PrereqAssembly.COMPPRMAP.xml’.
2014-05-05 08:55:03Z Loading data table ‘Microsoft.Dynamics.Setup.PrereqAssembly.COMPDATA.xml’.
2014-05-05 08:55:03Z Loading prerequisites for component ‘Databases’:
2014-05-05 08:55:03Z Computer restart pending
2014-05-05 08:55:03Z Microsoft .NET Framework 3.5 Service Pack 1
2014-05-05 08:55:03Z Domain user account
2014-05-05 08:55:03Z Adding prerequisite ‘Computer restart pending’.
2014-05-05 08:55:03Z Adding prerequisite ‘Microsoft .NET Framework 3.5 Service Pack 1’.
2014-05-05 08:55:03Z Adding prerequisite ‘Domain user account’.
2014-05-05 08:55:03Z C:\Users\dominic.m.DIPL\Desktop\DynamicsAX_2012 Feature Pack
2014-05-05 08:55:03Z Components selected:
2014-05-05 08:55:03Z Databases
2014-05-05 08:55:03Z Checking the following prerequisites:
2014-05-05 08:55:03Z Performing a computer restart pending check for prerequisite ‘Computer restart pending’.
2014-05-05 08:55:03Z Check succeeded.
2014-05-05 08:55:03Z Performing a registry value version check for prerequisite ‘Microsoft .NET Framework 3.5 Service Pack 1’.
2014-05-05 08:55:03Z Searching for a minimum version of ‘3.5.30729.1’.
2014-05-05 08:55:03Z Version found: ‘3.5.30729.4926’.
2014-05-05 08:55:03Z Performing a domain account check for prerequisite ‘Domain user account’.
2014-05-05 08:55:10Z S161InstallModelDatabaseTypeOption
2014-05-05 08:55:13Z Property InstallDatabase set to: ‘1’
2014-05-05 08:55:13Z S162ModelSqlServerEntry
2014-05-05 08:55:50Z Property DbSqlServer set to: ‘DOMMY\SQLEXPRESS’
2014-05-05 08:55:51Z Property DbSqlDatabaseName set to: ‘MicrosoftDynamicsAX’
2014-05-05 08:55:51Z Property DbSqlModelStoreBaseline set to: ‘MicrosoftDynamicsAXBaseline’
2014-05-05 08:55:51Z Property UpgradeDB set to: ‘0’
2014-05-05 08:55:51Z S620ModelSelection
2014-05-05 08:56:04Z OPTIONAL model C:\Users\dominic.m.DIPL\Desktop\DynamicsAX_2012 Feature Pack\Models\Labels\DynamicsAX2012-KB2627392-Foundation.axmodel is found.
2014-05-05 08:56:04Z OPTIONAL model C:\Users\dominic.m.DIPL\Desktop\DynamicsAX_2012 Feature Pack\Models\Labels\FoundationLabels.axmodel is found.
2014-05-05 08:56:04Z MANDATORY model C:\Users\dominic.m.DIPL\Desktop\DynamicsAX_2012 Feature Pack\Models\Standard\Extensions.axmodel is found.
2014-05-05 08:56:04Z MANDATORY model C:\Users\dominic.m.DIPL\Desktop\DynamicsAX_2012 Feature Pack\Models\Standard\Foundation.axmodel is found.
2014-05-05 08:56:04Z OPTIONAL model C:\Users\dominic.m.DIPL\Desktop\DynamicsAX_2012 Feature Pack\Models\Upgrade\ExtensionsUpgrade.axmodel is found.
2014-05-05 08:56:04Z OPTIONAL model C:\Users\dominic.m.DIPL\Desktop\DynamicsAX_2012 Feature Pack\Models\Upgrade\FoundationUpgrade.axmodel is found.
2014-05-05 08:56:04Z MANDATORY model C:\Users\dominic.m.DIPL\Desktop\DynamicsAX_2012 Feature Pack\Updates\DynamicsAX2012-KB2606916\Models\Standard\DynamicsAX2012-KB2606916-Foundation.axmodel is found.
2014-05-05 08:56:04Z MANDATORY model C:\Users\dominic.m.DIPL\Desktop\DynamicsAX_2012 Feature Pack\Updates\DynamicsAX2012-KB2606916\Models\Standard\DynamicsAX2012-KB2606916-SYPLabels.axmodel is found.
2014-05-05 08:56:04Z OPTIONAL model C:\Users\dominic.m.DIPL\Desktop\DynamicsAX_2012 Feature Pack\Updates\DynamicsAX2012-KB2606916\Models\Upgrade\DynamicsAX2012-KB2606916-FoundationUpgrade.axmodel is found.
2014-05-05 08:56:11Z Loading prerequisites for component ‘Databases’:
2014-05-05 08:56:11Z Computer restart pending
2014-05-05 08:56:11Z Microsoft .NET Framework 3.5 Service Pack 1
2014-05-05 08:56:11Z Domain user account
2014-05-05 08:56:11Z Microsoft SQL Server Full-Text Search
2014-05-05 08:56:11Z SQL Server Full-text Filter Daemon Launcher service startup type
2014-05-05 08:56:11Z SQL Server Full-text Filter Daemon Launcher service started
2014-05-05 08:56:11Z Adding prerequisite ‘Computer restart pending’.
2014-05-05 08:56:11Z Adding prerequisite ‘Microsoft .NET Framework 3.5 Service Pack 1’.
2014-05-05 08:56:11Z Adding prerequisite ‘Domain user account’.
2014-05-05 08:56:11Z Adding prerequisite ‘Microsoft SQL Server Full-Text Search’.
2014-05-05 08:56:11Z Adding prerequisite ‘SQL Server Full-text Filter Daemon Launcher service startup type’.
2014-05-05 08:56:12Z Adding prerequisite ‘SQL Server Full-text Filter Daemon Launcher service started’.
2014-05-05 08:56:12Z Adding prerequisite ‘Microsoft SQL Server (Databases)’.
2014-05-05 08:56:12Z S630Prerequisites
2014-05-05 08:56:12Z C:\Users\dominic.m.DIPL\Desktop\DynamicsAX_2012 Feature Pack
2014-05-05 08:56:12Z Components selected:
2014-05-05 08:56:12Z Databases
2014-05-05 08:56:12Z Loading prerequisites for component ‘Databases’:
2014-05-05 08:56:12Z Computer restart pending
2014-05-05 08:56:12Z Microsoft .NET Framework 3.5 Service Pack 1
2014-05-05 08:56:12Z Domain user account
2014-05-05 08:56:12Z Microsoft SQL Server Full-Text Search
2014-05-05 08:56:12Z SQL Server Full-text Filter Daemon Launcher service startup type
2014-05-05 08:56:12Z SQL Server Full-text Filter Daemon Launcher service started
2014-05-05 08:56:12Z Adding prerequisite ‘Computer restart pending’.
2014-05-05 08:56:12Z Adding prerequisite ‘Microsoft .NET Framework 3.5 Service Pack 1’.
2014-05-05 08:56:12Z Adding prerequisite ‘Domain user account’.
2014-05-05 08:56:12Z Adding prerequisite ‘Microsoft SQL Server Full-Text Search’.
2014-05-05 08:56:12Z Adding prerequisite ‘SQL Server Full-text Filter Daemon Launcher service startup type’.
2014-05-05 08:56:12Z Checking the following prerequisites:
2014-05-05 08:56:12Z Performing a computer restart pending check for prerequisite ‘Computer restart pending’.
2014-05-05 08:56:12Z Check succeeded.
2014-05-05 08:56:12Z Performing a registry value version check for prerequisite ‘Microsoft .NET Framework 3.5 Service Pack 1’.
2014-05-05 08:56:12Z Searching for a minimum version of ‘3.5.30729.1’.
2014-05-05 08:56:12Z Version found: ‘3.5.30729.4926’.
2014-05-05 08:56:12Z Performing a domain account check for prerequisite ‘Domain user account’.
2014-05-05 08:56:13Z Check succeeded.
2014-05-05 08:56:13Z Performing a service existence check for prerequisite ‘Microsoft SQL Server Full-Text Search’.
2014-05-05 08:56:13Z Checking for the existence of the service ‘MSSQLFDLauncher’ on the machine ‘DOMMY’.
2014-05-05 08:56:13Z Success
2014-05-05 08:56:13Z Performing a service status check for prerequisite ‘SQL Server Full-text Filter Daemon Launcher service startup type’.
2014-05-05 08:56:13Z Checking the startup type of the service ‘DOMMY’ on the machine ‘MSSQLFDLauncher$SQLEXPRESS’.
2014-05-05 08:56:13Z Found: ‘Manual’ Expected: ‘Automatic’.
2014-05-05 08:56:13Z Check failed.
2014-05-05 08:56:13Z Resolution: Use the Services Control Panel (Start > Administrative Tools > Services) to set the startup type to Automatic for the SQL Full-text Filter Daemon Launcher Windows service.
2014-05-05 08:56:13Z If you want Setup to perform this action for you, select the Configure check box for this prerequisite and then click the Configure button.
2014-05-05 08:56:13Z For information about how the prerequisite was validated, click the View log file link. For detailed troubleshooting steps, see the troubleshooting section of the Installation Guide at go.microsoft.com/…/
2014-05-05 08:56:13Z Performing a service status check for prerequisite ‘SQL Server Full-text Filter Daemon Launcher service started’.
2014-05-05 08:56:13Z Checking the status of the service ‘MSSQLFDLauncher’ on the machine ‘DOMMY’.
2014-05-05 08:56:13Z Performing a database version check for prerequisite ‘Microsoft SQL Server (Databases)’.
2014-05-05 08:56:13Z Attempting to connect to SQL Server ‘DOMMY\SQLEXPRESS’.
2014-05-05 08:56:13Z Searching for a minimum version of ‘10.0.2531.0’.
2014-05-05 08:56:13Z Version found: ‘11.0.2100.0’.
2014-05-05 08:56:13Z Adding prerequisite ‘Computer restart pending’.
2014-05-05 08:56:13Z Adding prerequisite ‘Microsoft .NET Framework 3.5 Service Pack 1’.
2014-05-05 08:56:13Z Adding prerequisite ‘Domain user account’.
2014-05-05 08:56:13Z Adding prerequisite ‘Microsoft SQL Server Full-Text Search’.
2014-05-05 08:56:13Z Adding prerequisite ‘SQL Server Full-text Filter Daemon Launcher service startup type’.
2014-05-05 08:56:13Z Adding prerequisite ‘SQL Server Full-text Filter Daemon Launcher service started’.
2014-05-05 08:56:13Z Adding prerequisite ‘Microsoft SQL Server (Databases)’.
2014-05-05 08:56:22Z Configuring prerequisite ‘SQL Server Full-text Filter Daemon Launcher service startup type’.
2014-05-05 08:56:22Z Initiating command ‘sc config MSSQLFDLauncher$SQLEXPRESS start= auto’.
2014-05-05 08:56:22Z Generating process ‘sc config MSSQLFDLauncher$SQLEXPRESS start= auto’.
2014-05-05 08:56:22Z Configuration of prerequisite ‘SQL Server Full-text Filter Daemon Launcher service startup type’ succeeded.
2014-05-05 08:56:24Z Adding prerequisite ‘SQL Server Full-text Filter Daemon Launcher service startup type’.
2014-05-05 08:56:24Z Adding prerequisite ‘Computer restart pending’.
2014-05-05 08:56:24Z Adding prerequisite ‘Domain user account’.
2014-05-05 08:56:24Z Adding prerequisite ‘Microsoft SQL Server Full-Text Search’.
2014-05-05 08:56:24Z Adding prerequisite ‘SQL Server Full-text Filter Daemon Launcher service started’.
2014-05-05 08:56:24Z Adding prerequisite ‘Microsoft .NET Framework 3.5 Service Pack 1’.
2014-05-05 08:56:24Z Adding prerequisite ‘Microsoft SQL Server (Databases)’.
2014-05-05 08:56:24Z Checking the following prerequisites:
2014-05-05 08:56:24Z Performing a computer restart pending check for prerequisite ‘Computer restart pending’.
2014-05-05 08:56:24Z Check succeeded.
2014-05-05 08:56:24Z Performing a domain account check for prerequisite ‘Domain user account’.
2014-05-05 08:56:24Z Performing a registry value version check for prerequisite ‘Microsoft .NET Framework 3.5 Service Pack 1’.
2014-05-05 08:56:24Z Searching for a minimum version of ‘3.5.30729.1’.
2014-05-05 08:56:24Z Version found: ‘3.5.30729.4926’.
2014-05-05 08:56:24Z Performing a database version check for prerequisite ‘Microsoft SQL Server (Databases)’.
2014-05-05 08:56:24Z Attempting to connect to SQL Server ‘DOMMY\SQLEXPRESS’.
2014-05-05 08:56:24Z Searching for a minimum version of ‘10.0.2531.0’.
2014-05-05 08:56:24Z Version found: ‘11.0.2100.0’.
2014-05-05 08:56:24Z Performing a service existence check for prerequisite ‘Microsoft SQL Server Full-Text Search’.
2014-05-05 08:56:24Z Checking for the existence of the service ‘MSSQLFDLauncher’ on the machine ‘DOMMY’.
2014-05-05 08:56:24Z Success
2014-05-05 08:56:24Z Performing a service status check for prerequisite ‘SQL Server Full-text Filter Daemon Launcher service started’.
2014-05-05 08:56:24Z Checking the status of the service ‘MSSQLFDLauncher’ on the machine ‘DOMMY’.
2014-05-05 08:56:24Z Performing a service status check for prerequisite ‘SQL Server Full-text Filter Daemon Launcher service startup type’.
2014-05-05 08:56:24Z Checking the startup type of the service ‘DOMMY’ on the machine ‘MSSQLFDLauncher$SQLEXPRESS’.
2014-05-05 08:56:24Z Found: ‘Automatic’ Expected: ‘Automatic’.
2014-05-05 08:56:25Z Adding prerequisite ‘Domain user account’.
2014-05-05 08:56:25Z Adding prerequisite ‘Microsoft SQL Server Full-Text Search’.
2014-05-05 08:56:25Z Adding prerequisite ‘SQL Server Full-text Filter Daemon Launcher service started’.
2014-05-05 08:56:25Z Adding prerequisite ‘Microsoft .NET Framework 3.5 Service Pack 1’.
2014-05-05 08:56:25Z Adding prerequisite ‘Microsoft SQL Server (Databases)’.
2014-05-05 08:56:31Z S240LastInfo
2014-05-05 08:56:38Z S250InstallProgressInfo
2014-05-05 08:56:38Z === Starting execution phase ===
2014-05-05 08:56:38Z Executing ‘Databases’ this pass.
2014-05-05 08:56:38Z Queueing for installation: Databases
2014-05-05 08:56:38Z Component installation task completed successfully.
2014-05-05 08:56:39Z === Setting up Databases MicrosoftDynamicsAX ===
2014-05-05 08:56:40Z Completed setup of Databases MicrosoftDynamicsAX.
2014-05-05 08:56:40Z === Setting up Full Text Catalog ===
2014-05-05 08:56:40Z Completed setup of Full Text Catalog.
2014-05-05 08:56:40Z Altering database MicrosoftDynamicsAX to modify size and growth for data and log files
2014-05-05 08:57:25Z Completed execution of Alter Database.
2014-05-05 08:57:26Z Completed setup of MicrosoftDynamicsAX.
2014-05-05 08:57:31Z The model store schema was not found in the database MicrosoftDynamicsAX.
2014-05-05 08:57:31Z Importing file ‘C:\Users\dominic.m.DIPL\Desktop\DynamicsAX_2012 Feature Pack\Models\Standard\Foundation.axmodel’ to the database ‘DOMMY\SQLEXPRESS\MicrosoftDynamicsAX’.
2014-05-05 08:57:32Z ******************************************************************************************************
2014-05-05 08:57:32Z The model store schema was not found in the database MicrosoftDynamicsAX.
2014-05-05 08:57:32Z Model import resulted in an error. See previous log messages for details.
2014-05-05 08:57:32Z Importing file ‘C:\Users\dominic.m.DIPL\Desktop\DynamicsAX_2012 Feature Pack\Models\Upgrade\FoundationUpgrade.axmodel’ to the database ‘DOMMY\SQLEXPRESS\MicrosoftDynamicsAX’.
2014-05-05 08:57:32Z Importing file ‘C:\Users\dominic.m.DIPL\Desktop\DynamicsAX_2012 Feature Pack\Updates\DynamicsAX2012-KB2606916\Models\Standard\DynamicsAX2012-KB2606916-Foundation.axmodel’ to the database ‘DOMMY\SQLEXPRESS\MicrosoftDynamicsAX’.
2014-05-05 08:57:32Z Importing file ‘C:\Users\dominic.m.DIPL\Desktop\DynamicsAX_2012 Feature Pack\Updates\DynamicsAX2012-KB2606916\Models\Standard\DynamicsAX2012-KB2606916-SYPLabels.axmodel’ to the database ‘DOMMY\SQLEXPRESS\MicrosoftDynamicsAX’.
2014-05-05 08:57:33Z Model import resulted in an error. See previous log messages for details.
2014-05-05 08:57:33Z The model store schema was not found in the database MicrosoftDynamicsAX.
2014-05-05 08:57:33Z Importing file ‘C:\Users\dominic.m.DIPL\Desktop\DynamicsAX_2012 Feature Pack\Updates\DynamicsAX2012-KB2606916\Models\Upgrade\DynamicsAX2012-KB2606916-FoundationUpgrade.axmodel’ to the database ‘DOMMY\SQLEXPRESS\MicrosoftDynamicsAX’.
2014-05-05 08:57:33Z ******************************************************************************************************
2014-05-05 08:57:33Z Object reference not set to an instance of an object.
2014-05-05 08:57:33Z Setup could not complete the installation.
2014-05-05 08:57:33Z Component installation task stopped due to an error.
2014-05-05 08:57:34Z S260FinishedInfo
2014-05-05 08:57:35Z An error occurred in function CreateSummaryReportDataForUpdates during generation of Setup Summary Report.
2014-05-05 08:57:35Z Sequence contains no matching element
2014-05-05 09:02:46Z === Setup was canceled or failed. For details see the previous messages in the log.
2014-05-05 09:02:47Z === Setup logging ended: 05/05/2014 09:02:47 ErrorLevel/ExitCode: ‘1’ ===
