Hello,
I have a form with a subform showing some records.
In a menu item I do some changes on the record data, and after doing this I would like to update (refresh) the records in order to see the changed data.
Which function should I use in the menu item? I tried CurrForm.UPDATE, CurrForm,UPDATECONTROLS, but it is not good.
I tried to refer to the subform using this: CurrForm.NameOfSubformControl.FORM.LocalFunctionToExecute;
LocalFunctionToExecute was UPDATE, but I did’t know what to write in the place of NameOfSubformControl. I tried Control100000006, which is the Name property of the subform, but it is not good.
I would like to create a function like View/Refresh.
Thanks a lot, Frida
