Hello,
I have a custom form named TOC_IdnTaxTransactionJourPostOpen and a button named Generate FP Sederhana. This button will display a dialog form.
when I select multiple rows in the form TOC_IdnTaxTransactionJourPostOpen, and then I click the button Generate FP Sederhana. it will show a dialog form, inside the dialog form I have to input the value. After that, I just want to update 1 field on the form TOC_IdnTaxTransactionJourPostOpen
my question is how to update multiple rows that I’ve selected on form TOC_IdnTaxTransactionJourPostOpen after I input the value from the dialog form?
public void run()
int cnt = 0;
TOC_IdnTaxTransactionJour idnTaxJour, updIdnTaxJour;
Args args;
MultiSelectionHelper selection = MultiSelectionHelper::construct();
FormDataSource fds = Args.record().dataSource();
selection.parmDatasource(fds);
if(fds.anyMarked())
idnTaxJour = selection.getFirst();
while(idnTaxJour)
update_recordset updIdnTaxJour
setting FakturPajak = CustGroupId
where updIdnTaxJour.RecId == idnTaxJour.RecId;
//cnt++;
idnTaxJour = selection.getNext();
Info(strFmt("Faktur pajak: %1", CustGroupId));
its my code, and got an error message “object reference not set to an instance”.
