hi,
i am using a transheader to calculate the amount in the previous page. How can i hide this section when there are no records or entry under it.
Plz help and thx in advance
hi,
if I understand you well then try this:
Add this in TransHeader OnPreSection
CurrReport.SHOWOUTPUT(Amount <> 0)
how can i specify the number of records under a transheader section?
there will be only one line correct ??? the Total from the Previous page.
because TransHeader is designed to be printed only once when a new page is generated
under the transheader section in the next page there no records.
i have the following output on my report:
rec1
rec2
amt1 amt2 (transfooter) my amount r comming wrong
on the next page
amt1 amt2 (transheader) —> under this section there no records
Ok…so the issue is there is another page getting generated without any records, but with the TransHeader Section Only. Am I Corrent ?
i want to know the numbers of records under the transhedaer section the show or no the section
