I have 4 fields in grid
Application number, price,qty,total amount
I have 5 records is there
outside of the grid I have one more filed is there amount
In grid what are total amounts are available to sum and display that in Outer field
can any one help me
table.field += table2.field;
Hi Ven,
You can use the below code example to return the sum of the TotalAmount field of all the records of Table2:
public Amount sumTotalAmount()
Table2 table2;
select sum(TotalAmount) from table2;
return table2.TotalAmount;
You can use the method sumTotalAmount () to assign this value to the field of Table1 accordingly.
Thanks & Regards,
Shankar Dutt Sharma
