I’d like to know how to sum all numbers in a particular field in a form. Can someone pls explain me.
Naveen Raaj.
Naveen Raaj.
What does that mean? Please elaborate…
Hi Kranthi,
For example
id itemname amount
1 PS/4 40000
2 xbox360 30000
i want to know how add the total amount of amount field
like this in form
total amount=70000
write a display method which calculates the sum and add it to the form
Mr.Kranthi can you please elaborate or explain with an example.
you can do like this this.field3= this.field1+this.field2;
you can also use select sum of particular field in the table and return the sum value in display method
