I created a grid with 4 columns(salesid, custaccount, salestype, and total line amount) in a second tab with a salestable datasource. The 4th column, total line amount, is a calculated field based on the salesid which will be used in SalesTotal construct which need the current salestable. I cannot find a way to grab the salesid when the grid is initialize or populated with records from the data source. Can somebody point me in the right direction or codes.
I can make a temp table for this but still doubting because it’s only 1 calculated field.
Thanks.
