Hi
I want add 2 fields in administration->users form
here i want to add 2 field…
in data source it was showing table is user info in tables its not there…
how to do this …
Hi
how to do this …
Hi Sunil,
Userinfo table is available in AOT-> system documentation->tables->Userinfo.
Regards
Kuppusamy S
Hi Sunil,
As said by kuppusamy,UserInfo table can be found in System Documentation — tables in the AOT,but you can add the fields in it…
Naresh kolli
Hi Sunil,
As said by kuppusamy,UserInfo table can be found in System Documentation — tables in the AOT,but you can’t add the fields in it…
Naresh kolli
I know that, That its sys object there its not allowing to add, may be with sys license code we can activate such objects.
Good…continue with it
