Hi everybody,
Due to some complications in implementing NAV, it was not possible to have the opening balances on 31/12/15(the previous year had transactions posted till 31/12/15).So, we registered the opening balances on 01/01/16. and 2016 transactions are posted from 02/01/16.
Are there any implications that I should be aware of?
Should there be any additional setup to prevent any possible problem?
Thank you,
Uaja
Hi Uaja,
As long as we are only talking about actual balance accounts, then you should be fine.
Did you also migrate open balance per individual customer and vendor on this date?
Hi Erik,
Thank u for your reply!
Yes, we have migrated the opening balances of vendors on 01/01/2016.
The problem might arise when running FOREX. Starting date should be 02/01/16 in order to prevent adjustments of the opening balances…
thanks a lot!
