setting up barecodes
I need to setting up barecodes in Dynamics Ax 2009.
How to do that ? and we can use it for each operation ( receiving goods, pick, pack, ship …etc) and how ?
thank you,
Mr.Abdel,
Pls check this link
http://microsoft-axapta.blogspot.com/2010/05/setting-up-bar-code-in-ax-2009.html
Thanks…
Hi Ishak,
Thanks for your reply,
I Careated a bar code With Type EAN 13 Under "“Basic → setup → Barcodesetup”
Than, I assigned the bar code to an Item In “INVManag → Forms → Item Details”.
Now My requirement is i want to print the barcode for that item. I Need to test the barcode for receiving goods or picking operation
Any Help…
thanks in advance,
Hi abdel,
You will get item barcode value(itemBarCode) from ‘InventItemBarcode’ table.
Best Regards…
Thank you
I am already creating the barcode for item “Inventory Management > Common Forms > Item Details > Setup > Bar codes” . But, i can’t print the barcode ?!! i can’t enter an order (sales or purchase ) using barcode ?!!
Kindly help me to find a solution to these points,
