Hello good people i would like to know which drivers can i use in the setting for an OKI Microline 512 printer under windows XP. Please help
Regards
Siya
Regards
Siya
If you’re talking about the Windows versions of Dynamics NAV / Navision, then you should use the standard Windows driver provided by OKI. Check at www.oki.com or www.okidata.com
Thanks for your Reply
Hi good people, i’ve tried to look up on the Oki Microline521 Manual and i found that i can make it to look like an EPSON Printer by changing the Emulation.
We have 10 site that uses Epson LX300 and one of them is using the OKI 521 and its the main Office. The other site are printing fine with the same settings, now i changed the driver to IBM GRAPHICS and the Emulation settings to Epson,but its not aligned correctly,your help will be much appreciated.
Regards
