I am just about to download and import the AX 2009 security profiler tool into our Test environment. I was just wondering, before I do that, is it possible to remove an xpo once it has been imported, and if so, how would I do that? The tool is obtained from:
This week end I had a chance to look into this tool. The xpo with private project consists about 10 objects. Out of this 2 objects are modifications to standard Ax objects (ClassFactory class and Administration menu).
If there are no customisation on these two objects, then you can safely remove this tool by deleting xpo.
FYI - for import into layers like VAR, CUS etc you should have license key. If you are a customer, then when you purchase development license you will receive CUS and VAR lience keys.
