Dear All,
I find the following message when I restore a backup file of navision database (fdb).
The following SQL Server error(s) occured while accessing the User Menu Level table:
601,“42000”,[Microsoft][ODBC SQL Server Driver][SQL Server]Could not continue scan with NOLOCK due to data
movement.
SQL:
SELECT[name],[usertype],[xtype],[length],[prec],[scale],[status]FROM"selcom".[dbo].[syscolumns]WHERE[id]=
OBJECT_ID(?)
I can actually delete the database abd recreate but I dislike to do it.
Any answers from you are apreciated. tku
Rgds,
Andreas
