HI All,
I am trying to import a text file which has fields seperated by tab space, I am tryng to import this file using variable format, then what value i have to set to “Field seperator” property?
Is there any other propertys that i need to set?
Please help me in this issue, its very urgent for me.
Venu
Hi Subrata,
I am getting an error while importing that says, "The text is too long , The text in code fields can have a max length of 2 chars"
But the size of that field is 10 in table designer.
Venu.
Kindly check your variable size if you are using any variable
Or else check if u r not importing the data in the wrong field
Regards
Amol
