Hi there. I’m looking at utilising the ‘Contacts’ feature, particularlly with Vendors.
When on the Vendor card, I select ‘Contacts’ from the ‘Vendor’ menu at the bottom and get the message:
You must specify Bus. Rel. Code for Relatiohship Management Setup Primary Key=’’.
I looked in relationship management setup, and where the code for bus rel setup is, there are no options to pick. Do I simply create codes? What is the purpose of them?
thanks, Mark
